twr
Hot Rolled
- Mar 18, 2014
- Kitchener Ont. Canada
Hi just out of the blue today while doing a tool change on my YCM the umbrella broke not sure why. After it happened i tried a tool change on the other side of the umbrella and it work fine. Any ideas to what may have happened?
I have a couple YCMs of the same vinatge, a 2000 in fact that has done the same thing.
Problem was the o-ring seals in the unclamp cylinder, not holding a seal anymore.
Way to check for this is to manually unclamp with no tool in the spindle, look up inside the spindle with a flashlight. While holding the unclamp button down, see if the fingers that grab the pullstub slowly close.
What happened with mine in this case was when grabbing a tool far from it's current position the unclamp cylinder would loose just enough pressure to allow the clamp fingers to close some. By the time it got around to the new tool and the head came down to pick up the next tool the fingers were closed just enough to push on the back of the pullstud and break the cast ALM unbrella. Tool was forced right through it.
It was an $80 rebuild kit from YCM, well except for the new ALM umbrella piece of course.
Well Alloy McGraw i think you hit the nail on the head! When holding the manual unclamp button it opens then starts to close after about 5 to 10 seconds so it need a seal kit for sure!! I also think the stroke is still to much as Vanc said it defecting more than .020 to .039 so I have 2 problems for sure. Alloy would you have the part number of the seal kit?
I have same problem no stock it has to come from Taiwan I bought it 5 years ago to switch from Bt40 to Cat40 mine came on the slow boat from Taiwan 5 weeks it was 300 shipping I think and 2100 plus tax. So what happen did he just let you buy another umbrella after only being on for 3 days? I never had a tool stick or not unclamp before but I see now it was just a matter of time with the claws slowly moving back when they should not! I got my brother to look at the umbrella and he thinks he can fix it and add some plate to make it stronger, he will start later this week to fix it. If it doesn’t work I will have to buy a new one Damm!
That’s to bad you lost 5 tools and as for the tech he should have knew something caused the problem, hell even I knew something else was screwed! I hope my brother can get it done correct he is very good aluminum welder he does it a lot much better than me welding aluminum. I just pulled the cover to look at the cylinder and with the manual switch held I can see it drop down and hit the mic switch when it should stay up, you were 100 percent right on what screwed up!
Notice
