PartScrapper9000
- Nov 14, 2018
This is probably a simple question but ashamedly this is something I have never actually known for sure.
Should the diameter of the tool (either shank or cutting flutes) be the specified diameter of the bit or undersized? For example if I have a 10mm end mill, should it be exactly 10mm in diameter anywhere in the cutter, or slightly undersized?
I have been measuring a bit of my tooling and some tools are the exact correct diameter specified while others are not. Some of my more expensive tools are undersized whereas some of my few dollar Chinese tools are the exact dimension stated, which really has me wondering.
I'm being fairly general, whether it be end mills, drills, taps, reamers, etc.
