Tool life 1/4-20 form tap in 6061?
Likes Likes:  0
Results 1 to 4 of 4
    May 2004
    Ridgefield, Wa USA
    609
    201
    74
    Default Tool life 1/4-20 form tap in 6061?
    I have tapped thousands of holes with a 1/4" - 20 form tap in 6061 and it seems to be still tapping fine how often do you change them out. The holes seem to be fine but I am thinking I should change it just because it has tapped so many holes. Flood coolant in Sharp VMC.
    Happy Thanksgiving.
    Jul 2008
    Gainesville, FL
    643
    792
    110
    I would keep using it until your no-go gage says otherwise. Even then, it should be a simple matter to remove the built-up aluminum from the tap and put it back into service for another 10k holes ...
    Removing aluminum from end mill
    Jun 2015
    Minnesota
    353
    8
    128
    Quote Originally Posted by gundog View Post
    Happy Thanksgiving.
    Funny... I've thought the same thing with the same tool. I decided to just keep using it. But like mbraddock said, if it won't gage right, then you'll know you've finally got toast.
    Dave
    Sep 2002
    People's Republic
    3,337
    275
    2187
    Check your minor diameter in addition to gage
    It will last forever but first thing to go is the minor won’t roll down to size
