Tool offset not working
Kenre
Cast Iron
Apr 25, 2007
Melbourne Australia
Havent used my lathe for a couple of weeks.
Some reason the tool offset isnt working. Weird. I am dialing in a new program and need to change the offset slightly to hit my dimension but nothing happens.
Everything else seems fine, just this strange issue. 3TD fanuc
Double checked the code, and that im keying it in correctly.
Any ideas where to look? ive run out of them!
You aren't able to change the valve in offset table? Or the control isn't applying the offset value registered? Either way odd :scratchchin:
Brent
I know this isn't a fix but a work around so you can run it could be to tweak the G50 by the incremental value needed to dial in size?
Brent
Brent, i should have been a bit clearer.
The control isn't applying the offset value. Keys in fine.
I went through the parameters also, everything is as i noted. Yes i have a copy written down.
That seems strange. The first thing I would do is check my tool call code that it's calling the tool up with the proper offset. Then I would rule out the machine by giving the tool offset and absurd plus offset like .250 and watch the cycle for that tool not even come close to the cut. That tells me the tool table is responding.
I have had cases during set up when my rough turn tool was cutting just under the finish size and I was chasing the finish tool offset because I could not see it taking a chip.
Good luck.
Make Chips Boys !
Ron
It's not strange, it's impossible. Whenever something likes this happens, the control is correct, the human is wrong. Controls don't refuse to pick up offsets. He's doing something wrong.
Not so. Although issues such as this are predominately program and programmer centric, indeed it can be a control issue. I'm currently working with a client to resolve a very similar issue. The control is randomly not applying the X axis Geometry Offset and the program is unequivocally correct.
When this event occurs, the error occurs repeatedly on the same tool, irrespective of any Reset or Manual Reference Return, or re-registering of the Offset as a possible fix. Recycling the power to the control has consistently resulted in a fix on the next cycle, but the same error generally occurs after the next few cycles and is random with regards to the tool the error occurs with.
The error never occurs on the Z axis, giving further weight to the fact that the Offsets (Geometry and Wear) are being called correctly in the program.
Can you show us a snippet of your program? Are you SURE the offset is being called up?
Not so. Although issues such as this are predominately program and programmer centric, indeed it can be a control issue. I'm currently working with a client to resolve a very similar issue. The control is randomly not applying the X axis Geometry Offset and the program is unequivocally correct........
Hi Bill, Can you post the model and firmware version (assuming it is Fanuc)? I'd like to look at my model-firmware info to see if it shows up as something odd.
No picking on it! its works, messy but been using the same layout with all my other codes.
N30 G00 G98
N40 G21
N50 G28 U0. W0.
N60 G50 X-199.00 Z420.0 S1700
N70 (FACE5)
N80 T0404
N90 M42
N100 M08
N110 G98
N120 G97 S1595 M03
N130 G00 X-79.84 Z149.92
N140 G50 S2000
N150 G96 S400 M03
N160 G00 Z1.334
N170 X-59.84
N180 G01 X-52.67 F400.
N190 X-49.84 Z-0.08
N200 X1.76
N210 X-1.07 Z1.334
N220 G00 X-79.84
N230 Z100.
N240 G97 S1595 M03
N250 M09
N260 G28 U0.
N270 (PROFILE ROUGHING2)
N280 M01
N290 M08
N300 G98
N310 G97 S1823 M03
N320 G00 X-69.84 Z149.92
N330 G50 S2000
N340 G96 S400 M03
N350 G00 Z0.92
N360 X-49.44
N370 G01 Z-41.58 F400.
N380 X-51.84
N390 G00 Z0.92
N400 X-47.04
N410 G01 Z-25.964 F400.
N420 G02 X-47.65 Z-26.173 R1.
N430 G01 X-48.65 Z-26.673
Just check the offset in tool 3 my centre drill running in the program, working perfect. even adjusted it .001 and re checked it, all ok there.
Most likely something in the code, but i cant see it. Will try another offset number and reset tool 4 to see if its a code or machine prob.
N30 G00 G98
N40 G21
N50 G28 U0. W0.
N70 (FACE5)
N80 T0404
N90 M42
N100 M08
N110 G98
N120 G97 S1595 M03
N140 G50 S2000
N150 G96 S400 M03
N160 G00 Z1.334
N170 X-59.84
N190 X-49.84 Z-0.08
N200 X1.76
N210 X-1.07 Z1.334
N220 G00 X-79.84
N230 Z100.
N240 G97 S1595 M03
N250 M09
N260 G28 U0.
N280 M01
N290 M08
N300 G98
N310 G97 S1823 M03
N330 G50 S2000
N340 G96 S400 M03
N350 G00 Z0.92
N360 X-49.44
N380 X-51.84
N390 G00 Z0.92
N400 X-47.04
Your using a g50 for your x shift, then you cancel it with the g28 z0.0
then you dont have it for the second time around. take it out and put is after then end of the tool.
it could also be you dont have a g00 before your tool call out. IE G00T0404
is this hand written code or form a cad system as the code looks really sloppy and confusing. I would edit your post to make the code easier to read. but tahst just me
Bingo! You found it Delw!
N260 G28 U0. should only be used when i change tools. Deleted it and now i can change the offset.
Its code from Fusion360, then edited in Dnc4u to make it work with 3T.
Thankyou very much Delw !! Legend!!
Hello Kevin,
I hope you're keeping well.
It may be some time before I get back to see the machine, as we are just about at total lock down, due to Covid-19. Accordingly, I can't tell you the firmware version, but the Control is a 10TE-F.
Best regards,
Bill
Hi Bill,
Thanks. Yes I'm well and lying low till the Covid 19 blows over. Hope the same for you. Got a few boat parts to make, keeping me in the shop a fair bit of the time.
Don't worry about the firmware info. My notes only go back to the 15 and 0 series. I'm surprised about a firmware bug, if it is one, in a 10 series. That has been around long enough and enough made that I would have thought it would have shown long ago.
Kevin
If you are going to use the G50, I would suggest using a G50 return to your start position rather than the G28.
Just the way I was taught. It's a lot easier to troubleshoot a program if you do, and you have control over where the tool goes.
Dan, I agree with what you just said and that is how I was taught too. But if your going to set your G50's and run from zero return then I don't know what difference it would make?
When running closer or from somewhere other than zero return then the return positioning G50 I see as a necessity.
Brent
I have to run g50's on my citizen with a 10T control.
well I dont have to I do to keep my offset numbers close to 0 on the x tools. I only have one offset page dont have wear offsets and geometry offsets.
I run the g50 at the start of the tool and cancel it at the end of that tool. for every tool that needs it in the x axis. my g50s are only in 1 place decimals like g50 U0.8 U0.2 etc then cancel it with a g50 U-0.8 U-0.2 etc etc. save the other places for the offset page.
at the end of my program I do a g28 u0.0. I have a short stroke and 2 turrets so its not huge problem to send it back.
I have a ton of tools so all my tools are tagged with the g50 number in both U and W. when I change them out I know what U and W to use and make sure my saved program has those numbers in before I run it.
when I was running big machines like above and bigger back in the day we used g50s the same way but didnt send the U and W home cause it was 30"- hundred inchs or so. in the am we would take the machine home and run a sub with the stored G50 u and w numbers that one time and be done with it until the machine was shut down or power went out.
I haven't got my head around the finer details of code. 3T uses G50 for part position as you know.
I know the G28 U0 sends the turret up out of the way for tool changes. I can specify in Fusion the return in Z for clearance, rather important with a long drill or boring bar!
This is the first and only CNC lathe ive ever run. Self taught with lots of help from here Im getting great parts so very happy!
