RMS Machine
- Nov 16, 2006
- NE Nebraska
Guys, had a project come across my desk that have I have not had to tackle before and need some new tooling.
The part is aluminum (6061) and is about 7" tall with a 4 bolt flange shape lofted to a circle (like a short stubby Christmas Tree)
Some parts are completely vertical and some have varying tapers going up the side.
I would like to machine this in a vertical configuration, stepping down to create the part.
I do not have ANY experience with tooling for machining something this tall. I am used to 1/2" end mill type stuff that is maybe 3" tall at most.
Any help on what to look for tooling wise? I have a HAAS TM2 with CAT40, the part has a minimum radius of 1.25" so maybe something about 2" dia? The bottom has a radius of 0.150" where it transitions to the flat section.
I usually buy with Maritool but the best I can find is a shell mill with a rectangular (APMT type) insert, but can only come up with about 5.5" reach after buying the right holder.
I am stocked with ER32 holders and up to 3/4" side lock holders.
Can you give me a little direction where to look for some tooling?
RMS Machine
RMS Machine
