markp
Hot Rolled
- Oct 7, 2006
- Petaluma CA 94952
My DMU103V is stuck in some weird mode with the toolchanger. Running a program, tool was being placed back in the umbrella and it didnt release correctly. I manually moved the umbrella back by cutting the air pressure, then grabbed the tool when it was unstuck on the umbrella. Now the yellow and purple toolchanger error lights are lit. AFAIK the recovery procedure is to clear the errors in diagnosis, go to manual Deckel/Maho mode, go to toolchanger pane and move the umbrella back and forth till the yellow or purple light quit blinking. Cant clear the errors though.
Im stuck in some mode where those yellow purple buttons dont do anything because I cant clear the two toolchanger errors. Also, in deckel/maho manual mode, the page for moving the umbrella shows a tool position of #5, even though the spindle had tool #4 in the spindle when this happened.
I was thinking I could reference everything but when I try to do that the umbrella slams forward like its trying to complete the tool change.
I reset the NCK but to no avail. I see a few references online on how to clear a toolchanger error on a DMC103V but nowhere is the successful procedure explained. Anyone happen to know? Maybe I need to reload the PLC and NCK?
