trochoidalpath
Cast Iron
- Jan 17, 2016
I sometimes need to finish a fairly deep (2-3") pocket in aluminum. I have been trying to use a reduced neck end mill (Helical 46361) for this -- it's a 0.500" dia, 0.625" LOC, 3.375" 3-flute.
The toolpath is a simple circular pocket. Speeds & feeds are 0.500-0.625" DOC, 0.020" stepover, 1700 SFM (13K RPM), 0.0026 IPT (100 IPM) in 7075. (These are straight out of the Helical calculator.)
The machine is a new Speedio, BT30 (not BBT). I am holding the tool in a Kaiser MEGA13 chuck with an on-size collet (<0.0001" runout).
But the surface finish on the walls isn't great. It's a little chattery and I get some witness marks and a clear horizontal line at each pass.
I can definitely back off the SFM and see if I can get it to behave... but I have been considering trying this with a hydraulic holder -- maybe a little more dynamic stiffness would help. Any advice?
