Toolholder type for 3D finishing
Results 1 to 18 of 18
    Jan 2016
    20
    Default Toolholder type for 3D finishing
    Thought I'd solicit some advice on toolholding for a BT30 machine doing 3D finishing. We usually run these with 1/4", 3/16", or 1/8" ball nose end mills, depending on the part, stepovers around a thou, in either 7075 or A2.
    Hydraulic chuck with a reducing sleeve? SK? Stick with ER because it's good enough? (We're not set up for shrink fit, so that's off the table.)
    Jul 2006
    Hillsboro, New Hampshire
    7,366
    1737
    5121
    Is this a Brother or a Roku-Roku? Best tooling in the world won't gain you much is the machine's not optimal for surfacing (a Brother in good shape won't be bad, but it's not a high-end surfacing machine).
    Are you having issues currently? If so, what?
    Jul 2012
    Washington
    2,806
    1077
    1121
    If shrink fit is not an option then my vote would be SK with precision collets. But I doubt you will gain much over good ER, maybe .0002" or so?
  4. Likes Mtndew liked this post
    Jun 2012
    Michigan
    4,628
    4240
    2796
    Quote Originally Posted by trochoidalpath View Post
    Not necessarily. You can get away with a propane torch, many people use this method.
    Waiting for them to cool is the only major issue.
  6. Likes GENERALDISARRAY, PhoneG28 liked this post
  7. #5
    Jan 2016
    20
    It'll be a Brother. We don't run these parts all that often.
    I am in absolute agreement that the best tooling in the world won't help if the machine sucks, since right now they're running on a Tormach. It's tough to pin down what's to blame for, say, poor surface finish, when there are so many variables at play. Right now we just baby the hell out of it until the parts come out okay.
  8. #6
    May 2017
    Minnesota
    972
    1177
    606
    When I was evaluating shrink fit I ran them with a MAPP gas torch. A bit slow, but worked great. Then I got Maritool's induction machine which is priced very competitively.
  9. #7
    Sep 2015
    CANADA
    Ontario
    96
    43
    36
    To add to this, ISCAR has a line of thin nose shrink holders they call "SRK" (they call their thicker ones "SRKIN") and it seems they need less heat to expand them enough to get a tool in compared to thicker ones.
    Probably not as rigid but for finishing they work good in my experience, and the clearance is great.
  10. Likes GENERALDISARRAY liked this post
  11. #8
    Jan 2013
    Gilbert, AZ
    5,815
    7299
    7413
    MST Deta-1 chucks are excellent MST DETa-1COLLET CHUCKSA-TYPE | Tecnara Tooling Systems, Inc.
    Click the PDF, look for part# 230-A070-4
    They are not cheap, and neither are the collets. But, run-out is very, very good.
    Otherwise? I just tossed an indicator on some MariTool SK10's. They are plenty good as well.
  12. #9
    Jul 2006
    7,366
    1737
    5121
    [Points to engine laying on garage floor] Ayup, that's your problem right there...
    Tormach's a marginal machine tool. A Brother in good shape is a big step up, but start with decent ER or SK tooling, no point YET getting the big-buck holders.
    Something to keep in mind - most cutting tools have good, but not perfect registration between shank and cutting edges, and the best holder in the world will not make up for that. In fact, you're better off with a holder than can be "knocked about" such that you can push the cutting edges into concentricity with the holder shank. But that takes careful work at the machine or in a dummy spindle, not a quick process.
  13. Likes fmari --MariTool- liked this post
  14. #10
    Jan 2016
    20
    Tell me something I didn't learn the hard way
    Once we get set up, we'll try this part with both ER and SK chucks, and see if it makes a difference. Thanks much!
  15. #11
    Feb 2014
    Sunny South West Florida, USA
    2,766
    10459
    3193
    FWIW, I only mention this because you mentioned reducing sleeves... Pretty much any of the big manufacturers will happily make you those smaller endmills with larger shanks, at about the same price as standards... Figure that way you don't have the added error of a reducing sleeve.
  16. Likes Philabuster liked this post
  17. #12
    Mar 2013
    Oregon
    1,766
    726
    2075
    If the machine is a Speedio, the High Accuracy settings are probably way more important than the marginal differences between high quality holders. Have Yamazen install firmware V10, use the new Quick Setting codes (M298 Lx/M299), and input the book rates they have.
  18. #13
    May 2011
    New Jersey
    2,015
    185
    1122
    We use plane old side lock holders in a vm2 and our results are excellent, to the point that hand finishing mold cavities is rare.
  19. #14
    Apr 2019
    Arkansas
    359
    50
    160
    Big Kaiser er collet holders and big Kaiser new baby mega collet holders and collets....look into them, buy them, never look back
  20. #15
    Nov 2005
    Illinois
    2,004
    210
    1527
    This is a great point that many people overlook or forget. CNC tool and cutter grinders don't have some special magical collet system that have zero runout. Some of the newer machines actually probe every part and can compensate for any runout during the clamping process. But even then you can easily have .0001-.0002 runout from the shank to the cutting edges. For good 3D surfacing you need everything to be on par. Good machine with a good spindle. Properly tuned servos and post processer that gives efficient code. Proper workholding. Good quality tool holder and collet ( if using a collet chuck) and good cutting tools.
  21. Likes Milland liked this post
  22. #16
    Nov 2005
    Illinois
    2,004
    210
    1527
    Quote Originally Posted by TeachMePlease View Post
    I do this all the time for tooling that I use for my production. 4mm ball endmill with a 1/4" shank, 7/16 ball endmill with a 1/2 shank, 3/8 5 flute finisher with a 1/2 shank. You get better runout and less deflection. Helps a lot.
  23. Likes Philabuster liked this post
  24. #17
    Jul 2006
    7,366
    1737
    5121
    Quote Originally Posted by fmari --MariTool- View Post
    Hi Frank,
    What's your estimate for the extra cost to do this? There's more grind time, wheel wear, and blank cost, so it's not insignificant, is it?
  25. #18
    Nov 2005
    Illinois
    2,004
    210
    1527
    Hard to say. Blank is more money. Carbide isn't cheap. Need to spin down the cutting diameter area. Every situation is different.
