I have suffered TTS slip with my Tormach power drawbar. I just replaced all the items with new and very carefully installed all the parts with anti-sieze. The Tormach info says to tighten the drawbar to 30 ft-lbs. My drawbar will not loosen the collet when tightened to any more than 20 ft-lbs.
Has anyone put a stronger air cylinder arrangement on a 1100? The stock air cylinder is a 100 mm diameter, 3 stage setup. I know the cylinder is Chinese, probably not as good as a high quality assembly, has anyone tried to take two of the 3 stage units and make one 4 stage unit to get 33% more push on the drawbar?
John
John
