Tormach spindle reverse
Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Mar 2017
    South Carolina
    17
    Default Tormach spindle reverse
    I'm not a machinist and the Slant Pro, and CNCs, are new to me.
    Can anyone help me with how to program the spindle to run in reverse to cut threads within PathPilot? Is it something as easy as editing the G code?
    I'd rather not have to buy yet another threading tool so I'm hoping to run the thing backwards. I'm currently waiting for Tormach tech support to call me back on this one.
    Sep 2006
    SW Wisconsin
    655
    125
    211
    Have you studied the spindle control M codes? Tormachs run a custom Linuxcnc implementation, it should have everything you need. Why do you need reverse for threading? LH or RH just changes your start position.
    Ed.
    Mar 2017
    South Carolina
    17
    I've looked over the code but I really don't know what I'm looking at just yet.
    Running it in reverse would let me keep the same tooling setup I have without having to buy another toolholder. And then have to change everything else because of it.
    If I can run it backwards and cut from left to right, it'd be the easier solution. Maybe.
    I'm very much new to CNC.
    Mar 2006
    PHILIPPINES
    2,913
    966
    1329
    I'm a bit confused. Are you trying to run a right handed tool in reverse to get a left hand thread?
    Mar 2017
    South Carolina
    17
    I'm trying to get this tool to cut a RH thread. If I can.
    It's at the bottom of the riser block, near the X-axis limit. If I flip it, it'll be 1/2" below center line. I don't have a way to make a riser block for it.
    I could buy another tool with the insert facing up and another riser block but that'd be another $300 or so.
    As best I can figure, it's either figure out how to run it in reverse or buy another tool again. And still have to figure out a way to fit it so I can clear the other tools, the chuck and have it fit in the X-axis.
    Apr 2018
    5,970
    2853
    Quote Originally Posted by 69boss302 View Post
    Umm, hunh ? If you run in reverse, the part rotates the opposite way. So you either have to put the tool on the opposite side or on the same side, flip it over and raise it up, so the cutting part is still on centerline. You'll probably need a new tool no matter what, unless you can put the one you have on the other side of the part.
    Did you pop out the plastic blanking plates and run air duct to the rear brakes yet ?
    Mar 2017
    South Carolina
    17
    If I run it in reverse, then the part would be turning into the cutting edge. The threading tool is oriented so that the cutting edge is facing down (slant bed, towards the operator). So as the part turns in the normal forward rotation, it actually contacts the underside of the cutter instead of the cutting face.
    May 2019
    Michigan
    2,401
    1236
    1761
    Are you talking about this POS? Tormach 15L Slant-PRO Lathe | Tormach
    I'm surprised you can actually thread with it.........
    Sep 2015
    Ohio
    1,429
    962
    1428
    Sounds like more than $300 worth of figuring.
    I'd buy the tool.
  10. Likes BT Fabrication liked this post
  11. #10
    Mar 2017
    South Carolina
    17
    Quote Originally Posted by ChipSplitter View Post
    It's good to see the love for the "hobbyist toy/it's not a real lathe because it's not a HAAS/Mazak/Doosan/big bull moose nut swinging lathe like I have at work" attitude still carries on. It was great to see it 3 1/2 years ago when I joined the forum. Makes my insides all warm and fuzzy to see it still today.
  12. #11
    May 2019
    Michigan
    2,401
    1236
    1761
    Machinery Discussion Guidelines
  13. #12
    Oct 2005
    19,495
    Don't really mater what you or anyone else "thinks".
    The site owner has rules....
  14. Likes ChipSplitter liked this post
  15. #13
    Nov 2019
    CANADA
    Ontario
    262
    317
    46
    tool holders are less then $70........ buy what works instead of screwing around to save 5 cents.
    im guessing lathe work is new to you also?
  16. #14
    May 2019
    1,425
    645
    837
    I'm cunfussed as to why M4 won't work
    The boring bar hanging out 17 Xd is rather comical
  17. Likes atex57, g-coder05, Bluejeep liked this post
  18. #15
    Sep 2006
    SW Wisconsin
    655
    125
    211
    Are you trying to cut on the back side with the spindle in reverse? You do know that M3 is spindle forward and M4 is spindle reverse? I think you better cut a lot of air before a work piece. What G code are you using for the threading?
    Ya, liked the stick out on the boring bar. ;-)
  19. #16
    Mar 2017
    South Carolina
    17
    Quote Originally Posted by Hardplates View Post
    If it was shorter, it wouldn't reach where I need it to reach in the diameter it needs to be in.
  20. #17
    Mar 2017
    South Carolina
    17
    What am I missing? It's not a manual machine and it's being used in my business as a production machine.
  21. #18
    Jun 2008
    Roanoke, VA
    692
    195
    275
    You should be able to thread in reverse (m4) starting in the thread relief and going away from the chuck. I wouldn't do that though, I'd flip the tool over and shim up the toolblock or modify the holder.
    I used a gooseneck threading holder (NSRDH163D) for ages in my old Mazak, it let you use a normal turning tool block (insert up, above the part) but offset the tool up so the insert faced down. You could cut your tool and weld it back together...
  22. #19
    Mar 2017
    South Carolina
    17
    Quote Originally Posted by BT Fabrication View Post
    I've been making my stuff for the past 3 1/2 years with a benchtop metal lathe rather successfully. And now I'm moving up to CNC as the business grows. I've used taps and dies for my threads. So this aspect of threading with the lathe is new to me
  23. #20
    Mar 2017
    South Carolina
    17
    Quote Originally Posted by Nmbmxer View Post
    Thank you.
