Toshiba Tosnuc 999 help
Likes Likes:  0
Results 1 to 2 of 2
    Nov 2010
    michigan usa
    5
    Default Toshiba Tosnuc 999 help
    Does anyone have the procedure to wipe the memory clean so we can reload the parameters? Our memory battery went dead and we can't get past the boot up screen. Have tried "S" button at start up but still have the NMI fail system down message. Thank you!
    Mar 2006
    PHILIPPINES
    3,044
    1114
    1488
    If its like my Toshiba MB horizontals with Tosnuc-500 there is a physical 3 position dip switch in the cabinet labeled:
    • RUN: Execute programs
    • EXE: Restore executive system software
    • CLR: System memory erase
    Just shut down the system and set the switch to what you are doing and then power up.
