I have a Tosnuc 777 control on a Toshiba BTD-11B CNC.
I am attempting to machine a 2 degree tapered bore with a 4" cutter.
I am getting a format error when trying to run the following
program. The error appears when I start moving in the "Z" axis
in the G03 mode on block N155. The following is part of the program
I am using. Would like to know what is wrong with this format.
("X" ZERO = CENTERLINE OF BORE)
("Y" ZERO = CENTERLINE OF BORE)
("Z" ZERO = FACE OF PART)
(4.00" DIAMETER X .375 WIDE INSERTED CUTTER)
(.375" ROUND INSERTS)
(OFFSET H1)
N100 G00 G90 G17 G80 G40
N105 G94
N110 G53
N115 G57 H901
N120 G00 G90 X0 Y0 S764 M03
N125 G43 Z5.0 H1 M08
N130 G00 Z.2
N135 G01 Z-8.8 F50.0
N140 Z-9.06 F20.0
N145 X.1 Y.2265 Z-9.08 F3.5
N150 G03 X0 Y.3265 I-.1
N155 G03 Y.3263 Z-9.09 J-.3263
N160 G03 Y.3258 Z-9.1 J-.3258
N165 G03 Y.3255 Z-9.11 J-.3255
N170 G03 Y.3251 Z-9.12 J-.3251
N175 G03 Y.3248 Z-9.13 J-.3248
N180 G03 Y.3244 Z-9.14 J-.3244
N185 G03 Y.3241 Z-9.15 J-.3241
N190 G03 Y.3237 Z-9.16 J-.3237
N195 G03 Y.3234 Z-9.17 J-.3234
(OFFSET H1)
N105 G94
N110 G53
N115 G57 H901
N130 G00 Z.2
N140 Z-9.06 F20.0
