tree journeyman 310, lubrication chart questions for maintenence
Likes Likes:  0
Results 1 to 1 of 1
    Aug 2010
    missouri, USA
    303
    19
    Default tree journeyman 310, lubrication chart questions for maintenence
    I posted this first in the general forum, but no responses.
    So moved the question over here. I had another question but had that answered by zps, but they could not remember the details of maintenance of the head of this machine.
    If anyone is not familiar the tree journeyman is the same machine as the 325, except it has a 3 phase variable speed head, similar to a bridgeport variable speed head.
    The lubrication chart on the side of the head is not discussed in the manual. the only thing it mentions in the manual is pulling the head @6 months to grease the spline on the upper spindle. My machine has a grease fitting on the baseplate between the head and the machine casting, im assuming that is one of the grease points in the chart, the guy at zps could not remember where oil went, or if there was another point for grease.
    has anyone had a j310 in the past and remember where to lube. see pic.
