ewlsey
- Jul 14, 2009
- Peoria, IL
I'm working on a really old Tree Journeyman 325. It has a Dynapath Delta 20 control. The issue it has is that the axes will not always be "in position" at the end of a rapid move and the control will just hang there forever waiting for the axes to be "in position".
The machine has a Servo Dynamics DC servo drive that's original to the machine. It uses Baldor DC servos with encoders. I think it may also have tachs on the motors.
I have gone through the servo tuning procedure provided by Tree, but I am not able to really reduce the servo lag. I tried to swap the servo drives with those from another machine, but I still have a lot of servo lag.
The only way I can get around the issue is to change the parameters and reduce the rapid speed. The Z axis is the worst offender, and I have reduced it all the way to 40 IPM. It's OK for the work this machine does, but I would like to find a permanent fix.
Any thoughts? I have not inspected the brushes, but I will. I suspect that the encoders are working OK because the machine does run fine at reduced rapids.
