First of all the warning. I am unsure if this is is specific to my machine, if something is wrong, but here goes.
I totaled a high feed face mill half a year ago. This was done by issuing the following type of code:
G1 Y100 ,R10
X100
As I recall the piece was firmly, firmly secured. I thought maybe it wasn't, but yesterday it happened again with my 80MM regular face mill (KSOM, 42 degree inserts or so, very fast) and the same type of movement. Thankfully it survived.
The result of the move using the 50MM high feed mill was, eh, dramatic. The workpiece was maybe 20kg P2. It just flipped over, right out of the vise and crashed into the spindle. The one I worked with yesterday apparently wanted to do the same, but it was stopped by a very durable material stop I had mounted on the left side of the piece, with the result that this stop was instead bent. Checking the vise, the screw securing it was still tightened and hard to untight.
So something is funky with that ,R option. For now I will avoid ever using it again. Opinions welcome.
The second thing is this: When using my high feed mill in full contact with the material (80% Ae or so,) I may have F'n'S at say Vc190 F0.8 and Ap 1.15mm. Translating it ending up at F5000-6000 or so. My G0 feed rate is 15000.
What would I then use for a trochoidal feed rate and how big an Ae would be recommended? We're talking 10' angle high feed mill.
G1 Y100 ,R10
X100
