CASEmechanic
- Jul 23, 2019
I80 CA23
Parameter output vis RS232
Set edit mode soft keyParameter output vis RS232
NC side, F2 PARM IN/OUT, F4 RS232C, set up parameters for output as follows.
UNIT: RS232C Parity: EVEN
PORT: 2 Xon/off: ON
BPS: 4800 RTS Cntrl: OFF
Stop Bit: 2 DR Cntrl: OFF
NC Cntrl: ON
Power off machine
Set rotary switch on FC200 board to a 2 (enable option parameters output)
Power on, Func. Select, parm. in/out, type 8 0's(password) "input"
Should appear
*Setting
*Parameter
*Seq. Prm&Keep Mem.
*Option Parameters
press input again
You will need a 25 pin to USB null pin modem cable
ready laptop or computer to receive (match comm. settings) I use PCDNC software
Make sure to adjust timeout to its maximum as it can take awhile for the control to output the parameters
press output
may take awhile to start and to output, normal for it to send a little then wait then send.
When it is done sending, it will say out put complete.
Your machine output parameters may differ from mine just make sure you set the computer to match your settings.
