sidetrack50
- Jul 1, 2014
- Indiana
Thanks everyone for your help so far, still trying to figure out why my ATC doesn't work. While at cold start position the screen saying I have tool "1" in the spindle (not too really in spindle) I type T 2 tool change, turret moves in place then spindle raises up about an inch or so then stops, at that point I hit jog and the turret retracts and I get about a 2 second fault message for X, Y, or Z then it goes to regular screen with no fault message.
So far I've removed a Watts filter that was leaking air, I cleaned the filter regulator on the incoming air line and change my incoming air hose to galvanized 1/2" pipe to make sure I have enough volume.
Tried looking at the online manuals but its a slow go trying to find my specific problem.
Is there a limit switch somewhere or is it still an air pressure issue, I have it set at 100 lbs.
