BobM3
Cast Iron
- Feb 23, 2006
- Minneapolis
I'm trying to make a 3/8-18 internal pipe thread using a 4 flute, .37 Dia. carbide pipe thread mill. I've tried 3 of the online G code generators but I end of having the same problem with each. The programs use tool compensation and I keep getting the same error:
Error 41 "Interference in CRC"
If I set the tool radius small enough (quite a bit less than .185) I can at least get through the code without any error messages.
I believe the problem is in the initial entry arc. Anyone else run into this? I'm sure I'm doing something stupid.
