Our business recently bought a used mazak and I've been lucky enough to be the new machinist. With some very basic knowledge and a lot of reading I've been able to run simple programs so far but it seems it has some problems relating to previously set parameters, such as coolant not turning on in auto mode as well as mazatrol coded programs not cutting correctly even when the tool path is showing exactly the desired cut. Any help or even a nod in the right direction would be a great help. Thank you in advance.
Also, I've made sure to get the correct z offset.
qt 250 - Album on Imgur
