Tsugami Oscillation cutting feature
danh14513
Sep 27, 2021
Has anyone used the oscillation cutting feature on the Tsugami? If so has your tool life dropped off when on? Ran a previous program on a new machine with oscillation on and tool life dropped off.
I haven't but always figured all that in and out of the cut would fatigue the insert. Interested to see if anyone chimes in. What model machine are you running, btw?
What's the material you're cutting, what're your parameters, and what insert/grade are you using?
Tsugami SS327-III-5AX. Parameters are dialed just curious if anyone has noticed a change in tool life using the oscillation vs not.
I would have to say that you Shirley will get less edge life with an interupted cut.
I have seen many times quicker wear on form tools running hex material, compared to a round part.
BUT:
You shouldn't be using that option if you don't need to.
And if you need to, then you are comparing less tool life to what - ratts nests?
Is that an option worth considering?
Think Snow Eh!
Ox
