Hi Orionsgn:
All good posts here; I'll just add a few tidbits from my own experience ( make lots of tiny stuff).
I will often take the insert and nip off the whole tool nose radius, then diamond hone a new one that's only 0.001" to 0.002" radius...just enough so you know it's there when you look at it under a microscope.
The second thing is to get it dead nuts on center or maybe 0.0005" below for external turning on small diameters but not more.
No that's not a missed zero...half a thou below MAXIMUM is what I go for, and I drop gauge each tool to be sure I get it there.
Now... I have a gang chucker instead of a turret machine and I run a lot of tools in parallel shank ER collet chucks so I can just rotate the collet chuck body to get it dead nuts and drop gauge off the table.
You will have to find another way...maybe a LH boring bar in a sleeve so you can do the same to get it as close to perfect as possible.
I typically do these things in several stages as Jobshopper TN describes in post # 5, but I program each segment of my finish pass with a radiused lead in and a radiused lead out and I leave VERY LITTLE for my finishing pass...maybe 0.001" per side using a very sharp insert with positive rake and the tip ground off on a super fine diamond wheel as described above.
My chips are like fine steel wool and no I don't try to chip break.
I also run cutting oil in my machine or just squirt on some Rapidtap if I don't want to slime the whole machine for one or two parts.
I typically start with oversize stock as BobW recommends in Post # 9 so it's nice and stiff.
If I have a bunch to do. I set up a separate finishing tool so I can preserve it, and my finishing passes have (naturally) a very slow feedrate so my miniscule corner radius doesn't end up cutting a thread instead of a finish pass.
I might go 6000 RPM and 0.0002" IPR to 0.0003" IPR.
Yes it all sounds terribly wrong and it'll rub and not cut and etc etc, but for weeny tiny skinny stuff it seems to work best for me, especially if I need to hit a good finish in 304 SS and don't get to abrasive polish in order to wipe out toolmarks.
Cheers
Marcus
