Turning between centers
Page 1 of 2 12 LastLast
Results 1 to 20 of 36
    Jul 2015
    ISRAEL
    Default Turning between centers
    I have a part that has to be turned between centers to maintain accurecy when taken out and in the machine in the procces.
    The plan is to allign the axel between the centers but i steel haven't figured out how to actually drive the part?
    Any ideas?
    May 2011
    New Jersey
    2,425
    213
    1305
    You need a lathe dog. They can be bought or made.
    Nov 2016
    UNITED KINGDOM
    108
    37
    27
    face driver
  4. Likes adama liked this post
    Nov 2017
    Kansas
    347
    79
    160
    I do all of my own driving, but if it’s an emergency you could call an ambulance.
    Feb 2011
    2,275
    1716
    971
    That guy.
  7. Likes fusker liked this post
  8. #6
    May 2011
    Milford, Ct
    131
    43
    27
    As stated...Lathe Dog or Face Driver are the most common methods. Sometimes if you're doing a light skim cut, just add a little more tailstock pressure, and then you don't need a driver.
  9. #7
    Jun 2010
    419
    123
    142
    Quote Originally Posted by plastikdreams View Post
    Quote Originally Posted by KristianSilva View Post
    face driver
    Quote Originally Posted by Coadster32 View Post
    Yep. Small diameter and fairly light cuts, tailstock pressure works. Just dont get too aggressive with the pressure, too much on a small dia part can bend it.
  10. #8
    Jan 2013
    Louisville, KY
    3,016
    7107
    2555
    Face driver if possible. Lathe dogs work well, but if runout is super-critical, the unequal mass of a lathe dog can cause strange things, and this gets worse the higher the rpm.
    If we're talking engine lathe speeds, then you're probably OK with a lathe dog, but if the runout & circularity is that critical, then stay as close to a face-driver setup [read: radially symmetrical, & dynamically balanced] as possible.
  11. Likes gregormarwick liked this post
  12. #9
    Jun 2013
    Oregon
    1,559
    553
    930
    Pretty vague. A wee bit more detail would aid your cause.
  13. Likes digger doug liked this post
  14. #10
    Virginia
    28,156
    7561
    8714
    Quote Originally Posted by Jashley73 View Post
    That applies only to the ancient ones, and they happen to be better balanced, dynamically than first appears. Lathes were slower, back in their day. It just wasn't a problem, nor need it be, now.
    In any case, it isn't at all hard to shop fab a VERY well balanced one.
    Two near-as-dammit identical bars, each with a Vee cutout arranged for equal length of bypass, opposite direction. Equal mass fasteners for clamping. That implementation must be easily 200 years old in use. A small "set" of forged loop and bent-tail were just handier.
    You want a Rzeppa joint for TS set-over tapers? Have at it.
  15. #11
    Feb 2007
    Aberdeen, UK
    3,664
    1264
    1430
    You can balance a lathe dog I guess, but they still prevent turning the entire OD in one setup.
    Face driver is better in every way. Especially the hydraulic ones that don't care about the precision of the face...
  16. #12
    Virginia
    28,156
    7561
    8714
    Quote Originally Posted by gregormarwick View Post
    Must be a stock item? Show us a link. Locomotive axles to carburretor metering rods, please.
    Otherwise, I'll stick with women for hydraulic "face driving", thanks!
  17. #13
    Feb 2007
    Aberdeen, UK
    3,664
    1264
    1430
    So, the basic principle is the driving dogs are actually hydraulic pistons which all share a common reservoir, and therefore conform to the profile of the face with equal pressure. I think Sandvik Kosta were the first to make such, but they are commonly available from a number of manufacturers now. They can be had in surprisingly small diameters.
  18. Likes litlerob1, mountie, pgmrmike, cameraman, Ox and 3 others liked this post
  19. #14
    Virginia
    28,156
    7561
    8714
    Thanks for that, Gregor.
    I'm sure it will benefit "someone". I just don't happen to be he, this incarnation. At least not until I get another two Delta-Wye transformers bought and can get back to serious workholder hoarding again..
  20. #15
    Jun 2010
    419
    123
    142
    Very interesting. Have never seen that type before. Thanks
  21. #16
    Aug 2002
    West Unity, Ohio
    25,551
    5794
    8174
    Well if that don't beat all!
    That is exactly what I envissioned from your previous description, but I really ??? the small chambers that it would have to be... ???
    The Hydramax vise jaws have much more biggerer piston sizes, but apparently this works, and if so - would be a God-send for castings and such!
    Think Snow Eh!
    Ox
  22. #17
    Oct 2005
    16,070
    I have seen these, those piston ends are very sharp (think knife blade, crossed with a one way screw head)
    I have seen the results, they leave a nice 6 way pattern
    on the end of the shaft.
  23. #18
    Nov 2013
    Utah
    4,674
    1238
    2618
    I wonder if the "blades" or Drive pins (per the model) are a consumable item. I would automatically think and assume; YES, but how easy/cheap/accessible are they to replace?
    R
  24. #19
    Oct 2005
    16,070
    R
    Yes, I have seen them replaced IIRC the operator was able to replace them.
  25. #20
    Dec 2008
    Vt USA
    6,802
    748
    2358
    Now do any here actually think that the OP , who is asking about what is likely his first attempt at between center turning, is going to spring for a hydraulic compensated face driver?
    Get real!
    Just getting both a drive plate and a center in the lathe at the same time is going to be an issue.
    Turning at "dog speed" is never going to cause a problem, that is why they invented carbon steel tool bits.
    Jeesh!
