Turning between centers. Need help.
Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Apr 2018
    Indiana
    22
    5
    Default Turning between centers. Need help.
    Going to turn a .937 shaft 20" long down to .815, my question is what is the best way to turn this all in one? I have a haas sl20 with a tailstock. My thoughts are put a dead center in chuck and a live center in tailstock, but has anyone tried this without a lathe dog? With the tolerances ive been given, I cannot flip or do a 2nd op turn on it, has to be all in one.
    Nov 2009
    Michigan USA
    1,106
    82
    231
    My way, center drill both ends. Have 10.2" stick out of chuck. Turn to size with a fillet or radius of at least the tool nose. Flip and do the same.
  3. Likes Bobw liked this post
    Jul 2006
    Arizona
    4,589
    18427
    4306
    Quote Originally Posted by sknies View Post
    You are not going to turn down a noodle like that unsupported.
  5. Likes Bobw, Booze Daily, doug925, Ox, 706jim and 2 others liked this post
  6. #4
    Nov 2013
    Utah
    4,516
    1193
    2502
    Like Phil said, that is just not going to work. You could look into "Box Turning Tools". You could do it in halves like athack said. You could do it by incrementally pulling it further out from the Chuck in sections.
    OR you could "no quote" it, because you don't have a CNC Lathe that isn't equipped for it. You have to support the middle.
    OOC; why no Lathe Dog?
    R
  7. #5
    Feb 2007
    Aberdeen, UK
    3,541
    1228
    1332
    Like the others have said, there's no way that's going to work.
    All I have to add is, when you want to turn between centres on a cnc lathe and make any kind of speed at it a driving centre is the way to go, not a dog. Much safer, can go faster, no balance issues etc.
  8. #6
    Apr 2005
    Beaverdam, Virginia
    7,359
    650
    3469
    I think you will end up roughing it out by pulling out a few inches at a time and then sending it out to a centerless grinding shop.
  9. Likes Philabuster, Silent_Man, mc3608, Bobw liked this post
  10. #7
    Apr 2019
    Arkansas
    382
    57
    167
    Quote Originally Posted by Dualkit View Post
    Bingo. Exact reason we bought a centerless grinder.
  11. #8
    Aug 2010
    Medina OH
    1,784
    131
    759
    I've sent a few items to be centerless ground, but I was under the impression, that centerless grinding a part that had to be concentric with... the center, was a nogo?
    How to do they do that?
  12. #9
    Aug 2002
    West Unity, Ohio
    25,240
    5517
    7946
    With the apparent qty of just one, just send the shaft to the C/L grind shop and have them just grind it down.
    No point you screwing around with it.
    Option 1)
    Buy from a Swiss shop - but 1 pc will likely be cheaper from grinder.
    Option 2)
    Use .015 rad inserts - and preferably 35* points if possible, and take small cuts and slow RPM to fight chatter.
    It might be dooable, but not worth it if you can find a [centerless] grind shop.
    Think Snow Eh!
    Ox
  13. Likes Philabuster, GM liked this post
  14. #10
    Jun 2013
    Oregon
    1,533
    537
    926
    I think it is doable. As long as your material is balsa.
  15. #11
    Jun 2012
    Michigan
    4,643
    4248
    2803
    Disregard this post
  16. Likes Bobw liked this post
  17. #12
    Nov 2013
    Utah
    4,516
    1193
    2502
    Quote Originally Posted by Mtndew View Post
    Just to add on what others have said about not being supported, how do you intend to drive the part if you're not using a dog?
    The second your tool touches the part it's gonna spin and you're gonna have a bad time.
    See Gregor's post. I've never used one, he swears up and down by them. I have to admit, if they work as well as he purports, they're pretty slick.
    R
  18. Likes gregormarwick, Mtndew liked this post
  19. #13
    Aug 2010
    Medina OH
    1,784
    131
    759
    Fancy new fangled contraptions can be seen here:
    https://www.riten.com/wp-content/upl...DUserGuide.pdf
  20. Likes Ox, TeachMePlease, Mtndew liked this post
  21. #14
    Feb 2007
    Aberdeen, UK
    3,541
    1228
    1332
    R
    I do, and they do.
    They've been around a long time, absolutely not a new idea. I first came across them years ago when I was learning the ropes at my dad's shop. He bought an old Rohm one on ebay as an impulse buy for peanuts more out of curiosity than anything else I guess.
    Turned out to be an extremely useful piece of equipment.
  22. Likes Ox liked this post
  23. #15
    Aug 2014
    California, USA
    63
    8
    48
    What material and what tolerance, did I miss that?
    Also, can you tap the ends? You can put a bolt in there and hold onto that as an alternative...
  24. Likes Ox liked this post
  25. #16
    Jan 2003
    Canada
    11,204
    5285
    3355
    I've only done that sort of thing on manual lathes with a follower. It can take a few tries to get it just right.
    There are ways to do it cnc, a 1 off isn't ideal, if its many you can spend some $ and time to rig up a proper follower or at least a steady.
    30+" rifle barrels get turned like that all day every day.
  26. #17
    Jun 2012
    Michigan
    9,968
    3359
    3572
    Very sharp tool bit so a light finish cut aluminum sharpness might help.
    Closer than .0005 and better have a very high quality live or a dead center...
    Agree I don't know beans about CNC lathes.
  27. #18
    Jun 2016
    Iowa
    125
    76
    53
    Use a follow-rest
  28. #19
    Oct 2011
    West-Central Illinois, USA
    1,229
    1987
    559
    Driving centers work cool, but with very high length to diameter shafts the driver dog spring pressure tends to aggravate chatter or help the part to spring away from the tool near the center of the shaft.
    Follow rests & box tools when set well will work hard all day long.
    Adding 3” to the part length with a collet or soft jaw chuck will work using good tool geometry & reasonable machining parameters (then cut the 3” drive end off).
    Good luck,
    Matt
  29. Likes gregormarwick liked this post
  30. #20
    Feb 2007
    Aberdeen, UK
    3,541
    1228
    1332
    fwiw, the slenderest shaft I've successfully turned with a centre, otherwise unsupported, in a slant bed cnc, was 15mm bar down to 1/2" over 13" long. 316L. I had one end in the chuck with excess material, as suggested by Matt above.
    On the advice of our sandvik rep, I did it in a single pass using a VBMT with a .2mm rad. I was extremely skeptical, but it worked a lot better than I expected, barely noticeable chatter and about .003" big in the middle.
    That was a long time ago on very nice Gildemeister lathe, with an exceptionally smooth, fast, ceramic bearing spindle and fantastic accuracy. I would not like to attempt the same on any of the lathes I have now. I was spoiled by that lathe, the new lathes that we have bought since have been bit of a harsh reality shock in terms of accuracy and capability.
    These days I put such parts directly to the sliding head guys, don't even think about doing it myself.
