Jashley73
Titanium
- Jan 24, 2013
- Louisville, KY
I'm hoping to mine others' experience here, specifically to see if there's anyone out there with success in turning softer steels by using CBN inserts.
The Background...
We have a long-running production job, where parts are induction-hardened, then brought in for finish-turning.
Trouble is, the parts are not hardened along their entire length, so there are hard & soft zones to turn through. Soft zones is 20-26 HRC. Hard zones are 50-55 HRC.
So far, our tried & true workhorse has been a carbide insert, which is designed for turning in situations such as these. Seco TH1000, MF2 chip-breaker. These inserts require a slower cutting speed (SFM) due to being carbide, and the wear-resistant coating being relatively thin. If we could cut these parts faster, obviously that's a win...
Today's challenge...
Today however, we're running a similar part where the soft material zones are 30-35hrc, and again, hard zones are 50-55hrc. Tool life with the TH1000 insert is drastically lower, while using an even slower cutting speed.
Today, I dug through some old sample inserts, and found a Sumitomo chip-breaking CBN insert. Tossed it in, 750sfm across the hard & soft zones, dry cutting.
Interestingly, the tool cut well. It did not crumble the edge in the soft material, as we've seen with other CBN trials in the long-running part. Surface sheen/finish looked great. And despite dry-turning, the part stayed cool - never getting above 'just barely above ambient temperature to the the touch.'
But, sizing was a mess... Diameters were all over the place across the different part features. Adjusting the offsets to bring the part into spec, showed even more variability, and un-even stock removal compared to the previous cut. The next part was just the same. Great finish, good insert performance, terrible size control.
Total stock for finish turning was .020"/.5mm per side.
We get excellent consistency with the TH1000 grade, so this un-predictability with the CBN tool was unexpected.
Question #1 - Has anyone on here had luck using CBN tools on softer material?
Question #2 - For those with experience turning hardened steels with CBN - How much stock do you leave for finishing?
The Background...
