Turning over 40 x D parts
Page 1 of 2 12 LastLast
Results 1 to 20 of 24
    Feb 2019
    CANADA
    Ontario
    44
    Default Turning over 40 x D parts
    Hey guys, has anyone tried turning with both upper and lower turrets starting in the middle with a slight overlap and turning in opposite directions; one toward the main and the other toward the sub? I was also wondering about starting at opposite ends and turning toward the middle. Anyone have experience doing this? What are the outcomes? Thanks guys!
    Nov 2013
    Utah
    4,991
    1311
    2825
    Why?
    I haven't tried that, but my guess is that your 40xD is going to Chatter. Why not conventionally pinch Turn from one end with bothe Turrets?
    R
    Feb 2019
    CANADA
    Ontario
    44
    Why?
    R
    I tried that (balanced not pinched) and still got chatter. Even tried increasing SFM to move it out of the frequency and increased the feed. Also tried decreasing SfM. Do you find pinch turning yields better results than balanced?
    Jul 2006
    Hillsboro, New Hampshire
    9,589
    2249
    6644
    One turret - shallow "V" shaped follower pad made from slippy, robust plastic. Other turret - turning tool.
    Turning turret starts cut from whichever end of stock. After ~1" of turned surface, following turret with V pad locates on freshly turned section, and (shock!) follows cutting tool along cut surface.
    We OF's call them following rests. Still works, even for you young whippersnappers and your newfangled CNC machines. Follower should be on the upper turret to minimize chip incursions. Better still, plumb coolant to the pads to constantly flush and lubricate the plastic.
    Nov 2013
    Utah
    4,991
    1311
    2825
    Quote Originally Posted by Tupper87 View Post
    I think there is discrepancy in the definition, it's irrelevant except in the interest of getting answers. Pinch Turning; as I understand it is both Turning Tools running the exact same path at the exact same X and Z location, just double the feedrate (theoretically).
    Balanced Turning; as I understand it is Using a Roughing Tool 180º about and a tiny amount ahead in Z from a Finishing Tool.
    Both of these start Turning from the one end though. I have had good luck eliminating Chatter using (as defined above) Pinch turning, but I have not had luck using it for mass Material removal.
    Either way, try Milland's suggestion of a programmable Follow rest. I haven't Done what you are asking, so I'm useless.
    R
    Mar 2008
    vacaville ca
    495
    69
    136
    I saw this a few years ago and they used a heimbuck(sp?) chuck to do this.
    YouTube
  7. Likes Mtndew, CNC Hacker, barbter, aarongough liked this post
    Jan 2007
    Norfolk, UK
    20,072
    15473
    15822
    You say 40X D, what diameters are you working on?
  9. #8
    Aug 2002
    West Unity, Ohio
    26,353
    6649
    8715
    Limey x2
    40D at what size and material?
    How much material to come off?
    40D is not 40D is not 40D.
    .125 x 40 is not the same as 1.25 x 40.
    Tool pressure is a more constant, and the 1.25 bar won't notice it nearly as much as the .125 bar.
    Can you use a box tool?
    Think Snow Eh!
    Ox
  10. Likes Limy Sami, Oldwrench liked this post
  11. #9
    Feb 2019
    CANADA
    Ontario
    44
    Limey x2
    Think Snow Eh!
    Ox
    7.8mm x 312mm.
    1.725mm has to come off.
    No box tool cutter. Atm the tooling I have is what I'm stuck with. May either Jerry rig a follow rest or convince my boss to buy me a box tool. Don't know much about them. Do they adjust to multiple OD's typically?
  12. #10
    Feb 2019
    CANADA
    Ontario
    44
    Quote Originally Posted by pcasanova View Post
    YouTube
    Fuck me that's genius! So going to try this! Just not sure the stroke on the jaws. If the ID on the jaws isnt much bigger I see it working. But i dont know how well this will work if the ID of the jaws has a large size difference in comparison to the OD of the part.
  13. #11
    Aug 2002
    West Unity, Ohio
    26,353
    6649
    8715
    Get on ebay and buy a box tool.
    They are adjustable.
    We may need to help you git it set up.
    That vid is machine specific, and that's what they are showing.
    I am guessing that they have what is known in Star language as a "Magic Guide Bushing" on this machine.
    Similar products sold by Walter Dunner SA in Switzerland. But at $20K/each, the box tool is likely your best choice in the short term....
    Think Snow Eh!
    Ox
  14. Likes Limy Sami liked this post
  15. #12
    Jul 2006
    9,589
    2249
    6644
    Yeah, the "Swiss" process that video shows it pretty sweet. But you have to be aware of critical speed too, which varies with material stiffness and RPM. At some point the L/D can allow the material to "whip", or exceed its critical speed, so even supported at both ends, or with a box tool or follower, you may have to turn at a slower speed than you'd like.
  16. #13
    Nov 2013
    Utah
    4,991
    1311
    2825
    I would try it too. Just don't get your hopes up, usually you need a certain software and hardware handshake. As the old guy pointed out. But there may be a way to get around it, if you are bound and determined to make it work. We have no idea what control you are using, that might clue us in on what will work and what won't.
    But a Follow rest will be usable, and a Box Tool will too, regardless of the control and interface. Can't say if a Follow rest will solve your problem.
    R
  17. #14
    Mar 2008
    vacaville ca
    495
    69
    136
    the machine isn't anything special, it's all in the chuck. hainbuch is the company who does the workholding.
    its a dual channel 840d siemens. And timing on the siemens is dead simple, trailon command. specify leading axis,slave axis and ratio of movement and command x1 to move and slaves to x2 goes right along with it.
    Not sure if fanuc has the same axis coupling command.
  18. Likes barbter liked this post
  19. #15
    Jan 2007
    Norfolk, UK
    20,072
    15473
    15822
    Think Snow Eh!
    Ox
    X 2 on Ox, save yourself the grief and unnecessary complications and get yourself a box tool.
    And for those who don't know what we're on about YouTube & YouTube & YouTube
  20. Likes barbter liked this post
  21. #16
    Oct 2007
    SPAIN
    4,096
    2420
    1648
    I'd seen in the flesh but never used a box tool. I just looked at the vids you linked.
    Awesome piece of kit.
  22. #17
    Jan 2007
    Norfolk, UK
    20,072
    15473
    15822
    Quote Originally Posted by barbter View Post
    How about 1 5/8'' nickel aluminium bronze (and a special hard and tough brew for the Admiralty to boot ) down to 3/4'' dia +/- 0.0015 finished!! for up to 12+'' long, in 1 cut, running a brazed carbide tool in the box, at (if memory serves) about 300 RPM and about 0.008'' / rev (it was very abrasive, so the speed was kept low to get the tool life - essential when the orders were several 00's)
  23. Likes barbter liked this post
  24. #18
    Aug 2002
    West Unity, Ohio
    26,353
    6649
    8715
    I don't believe that I have a command like that on my 2000 Fanuc, but I'm not seeing anything done there that I couldn't doo. Short of _ of course the Swiss part.
    Obviously the chuck just keeps slight tension on the part during the pull. Actually, I don't see why someone couldn't doo that with about any other chuck if they wanted to. All you need is a low pressure feed line to the chuck and switch between the two. That's more involved than you want to get for one job, but really wouldn't be all that hard. And an M code of course.
    Think Snow Eh!
    Ox
  25. #19
    Sep 2010
    Victoria Australia
    3,911
    1581
    That's so when only tapers and plain turning is involved, but not so when all aspects of turning is involved, such as Circular Interpolation. In this regard, the whole package must be capable of Trajectory Interpolation across mixed axes, that is X for one spindle and Z for the other spindle.
    There are many MTB that offer such machines. Mazak have a Twin Spindle (in various sizes) with at least two linear axes per spindle (basically a Left and Right Hand lathe joined together) with a function labeled Swiss Mode. In this Mode one spindle provides the Z axis and the other the X, with true interpolation across the two axes. This is not possible with simple electronic gearing that you're referring to.
    Hello Ox,
    Its not all that simple. A lot of twin spindle, multi axes machines don't precisely know what each axis of one spindle is doing in relationship with each axis of the other spindle. Accordingly, without electronic gearing, or the capability of Trajectory Interpolation across typically unrelated axes, the best you could do is rely on timing between the two spindle axes to produce a result. Plain parallel turning would be possible, but anything past that is a fudge.
    Regards,
    Bill
  26. Likes barbter liked this post
  27. #20
    Aug 2002
    West Unity, Ohio
    26,353
    6649
    8715
    Yeah, if you were puting some fancy rads in there, then I am out.
    But what I see there is strait cuts with chamfers.
    I wanted to slave my Z2 to my Z1 once on a live tooling job, but wasn't able to on my machine.
    Think Snow Eh!
    Ox
