Turning with Rohm face driver
Likes Likes:  0
Results 1 to 6 of 6
    Aug 2013
    Illinois
    79
    12
    Default Turning with Rohm face driver
    We are turning with rohm face driver, and have occasional runout problems on the drive center end up to .005 or so.. Others .001 or better..
    Parts are about 3" dia x 16" LG.
    Runout at the spring loaded center is good. We are putting plenty of tailstock pressure to it, and parts are not spinning.
    Anyone out there with experience troubleshooting facedrivers?
    Feb 2007
    Aberdeen, UK
    4,811
    1784
    2371
    Which type of face driver and how are you holding it?
    Jan 2007
    Flushing/Flint, Michigan
    11,089
    663
    8874
    One trick with these is that the very first entrance cut has to hard and fast. This a big key. No nice and gentle start. Hit it hard.
    Otherwise they do not bite in good enough and walk. The spring loaded center does not have enough force to prevent this. It just backs out.
    Also seen spring loaded loaded centers that indicate great in free state but have slop in the hole so do not center well if the part loaded off.
    My experience is much small dia but about the same length and longer. (transmission shafts).
    The second question is is the error seen always or with drivers used for a bit?
    Bob
    Aug 2013
    Illinois
    79
    12
    Its a #5 or #6 morse taper shank driver. The taper shank is in a straight shank sleeve. We are chucking the sleeve in soft jaws.
    Aug 2002
    West Unity, Ohio
    27,876
    8197
    9880
    Can you adjust the pressure on the spring?
    Can you replace the spring?
    Think Snow Eh!
    Ox
    Feb 2007
    Aberdeen, UK
    4,811
    1784
    2371
    Quote Originally Posted by kla64 View Post
    That's not what I meant. Is it the hydraulic pin type or the blade cup type? The latter need a square face, or it will deflect off-centre.
