implmex
- Jun 23, 2002
- Vancouver BC Canada
Good morning All:
I have stepped washers to turn from 1" brass bar.
I currently turn one. bar pull, turn another, bar pull etc etc.
The turning cycle time is short...under 20 seconds so the unclamp, pull reclamp operation set is getting to be a major part of the cycle and it's noisy as hell too with the pneumatic collet closer hissing and farting every 20 seconds or so.
What is YOUR favourite way to make ten in a row and then do one bar pull and then another ten in a row, and another bar pull etc etc. (they're skinny so the stickout to turn ten is not a problem)
If I was just parting off washers I'd just code the whole works longhand, but there are enough operations in each part I don't want to write all that code, I want to run some sort of subroutine so I can just call it as many times as I want, offsetting it in Z after each repeat.
How would you code it?
The control is a Fanuc Oi Mate TC on a Prodigy gang chucker.
All suggestions will be greatly appreciated.
Cheers
Marcus
Cheers
Marcus
