hoot
- Apr 23, 2012
- Garnet Valley, PA
what is the difference between a whistle notch adaptor and a standard end mill adaptor?
Shame on kenametal for trying to coin that name..
Like DMF said weldon shank was a common term.
It means a screw to hold the tool and the whistle notch was/is a flat on the cutter or shank with a flat that is an angle most often 3 to 5* and angled so the tightening of the screw pulld the shane into the holder.
The Weldon shank was often flat(not angled) so it would hold well and the shoulder of the flat notch would keep the shank from sucking down.
whistle notch .. the angle kept the shank solid from moving up or down. Often a double set screw would be used..
While we’re on the topic, does anyone have any actual experience supporting the practice of pulling the end mill “out” before final tightening of the set screw on em holders to take up any slop in the “right” direction? I’ve always done it that way and never really felt like I’ve had the time to stop doing it and see if it does, in fact, lead to more broken em’s.
A weldon flat is like it's name implies a flat. A whistle notch has back taper to hold the tool in.
Edit looks like michiganbuck beat me to it.
Notice
