Triallyr
- Jan 28, 2009
- Aurora, CO
I think I've read through all the threads concerning turret indexing but nothing helpful to my problem.
I have a CK1 lathe that indexes nicely going CCW but misses more often than not going CW (toys to clamp but is slightly off). If I manually rotate the turret (not calling a tool but just pushing the rotate button) it goes clockwise, so Im thinking something is worn or off on the CW rotation. I have adjusted the proximity sensors to no avail and the problem seems to come up more frequently as the machine warms up. Also, if I increase the hydraulic pressure to rotate the turret faster the problem gets much worse. Since it doesn't appear to be the proximity sensor (although I have a new one ordered just in case), could it be related to the hydraulic motor overrunning one direction or not clamping quick enough one direction because it has something worn from mostly going CW?
Thanks for your help,
Steven
Steven
