Alright, What I am working with in the shop is a Yama Seiki GTH-2600M twin spindle lathe with a Fanuc 0i controller. We are utilizing a gantry to automatically load and switch the parts out of the chucks in the processing. The question presented to me by one of our set up guys was this;"Is there a way to keep the 2nd op program from reading the end of it's program (to keep it from triggering the gantry) before the first op lathe program is finished with it's process?" The reason for this is that the lathe locks the doors to the point that the operator can't get into the first op spindle when a tool life's out to change the insert if the 2nd op program has finished out. The only way to get into the work space if that situation comes up is to "RESET" the lathe programs to be able to unlock the doors.
I was wondering if there was a way to hold the second op program (in a wait mode of sorts) until the M30 code is read in the first op program? Then the 2nd op program could read the M30 in its program and continue as normal. Is there a way to cross communicate between sides in a twin spindle lathe environment? I look forward to see what you have to say on this. Thanks
