atgordon
Cast Iron
- Dec 28, 2008
- Hampstead, NC
I have a very lightly used Clausing Kondia FV1-CNC that dates back to 1994. It runs well, but has a very limited onboard memory capacity ( about 3500 lines of code, but only if the code is economic since every character counts, even line numbers!). Up to now, it has coped with everything I've asked of it, but I now have a profiling job for a customer that requires a lot of machining of draft surfaces ... the size of my programs has mushroomed as a result, and having to break the program into chunks is a pain (and very time consuming).
An upgrade to Delta 20 (OK, a slightly less elderly dinosaur) would give me drip feed capability ... I've just completed the upgrade and wanted to share the how to:
1. Make note all of all tool and offset settings (T and E), and Machine Home, since they will be lost in the change over (don't ask me how I know) ...
2. Buy a Dynapath Processor Board #4202731 (they all come with a letter suffix, indicating the revision level: the higher the letter, the better).
3. With the machined turned off, remove the current Dynapath Processor Board, after disconnecting the 15 PIN DIN, and the 2 Pin MOLEX connectors.
4. Remove the 40 pin DIL chip labelled MP/MILL from the old board, and place it in the new processor board - this chip contains all the current machine setup parameters SO IS VERY IMPORTANT.
5. Insert the processor board in the rack, and reconnect the DIN and MOLEX connectors.
6. Fire up the machine ... you will see a lost parameter error. Hit reset and it goes away.
7. Check that the machine homes correctly ...
8. Re-enter all HOME, TOOL and OFFSET params and you good to go!
ATG (keeping an old machine working and making money!)
