Using CMD Extreme Pressure Lube #3 to keep tools from sticking in the spindle
Results 1 to 8 of 8
    Jan 2003
    Pacific Northwest
    1,393
    109
    Default Using CMD Extreme Pressure Lube #3 to keep tools from sticking in the spindle
    I've tried several greases and CMD Extreme Pressure Lube #3 seems to work the best on my CAT 40 tools. Just keep everything clean and wipe a very thin layer of it on the spindle taper. Maintain as necessary. Seems to work very well.
    Feb 2014
    FL
    3,445
    11755
    3954
    Quote Originally Posted by laminar-flow View Post
    Careful, Doug's gonna come along and call you a shill/spammer.
    Oct 2005
    17,852
    Quote Originally Posted by TeachMePlease View Post
    Nope, I was gonna suggest the chuck grease sold at my local bearing house.
    Might be easier to source/cheaper is all.
    Good tip nonetheless, you always see toolholder sockets dry as a bone.
  4. Likes TeachMePlease liked this post
    Mar 2012
    Geilenkirchen, Germany
    2,564
    1511
    1309
    I know it is expensive, but I use LPS2.
    Sep 2006
    SW Wisconsin
    573
    50
    153
    Is lubing the spindle taper something I should know about? Did I misread this? The reason for asking is I just purchased my first VMC.
    Ed.
    Nov 2017
    POLAND
    15
    Dmg here recommended for dmc 63v the Molykote Powder Spray it works great.
  8. Likes 5 axis Fidia guy liked this post
  9. #7
    Jan 2003
    Pacific Northwest
    1,393
    109
    I'm not sure what is recommended by the manufacturers, but I can't see any reason not to have something between the hard steel spindle and the bit softer steel taper. The high pressure lube seems to be the best at letting the taper release. But I have only tried a few greases so there may be better stuff out there. Too thick of a layer would or could cause accuracy error though, so just a thin coating is all I use. What do some of the other CNC machine manufacturers recommend?
  10. #8
    Mar 2012
    2,564
    1511
    1309
    The LPS family includes 1,2 and 3 where 1 is the least viscous. Both 1 and 2 leave very little film. I prefer 2 for medium time protection (6 months).
