npolanosky
Cast Iron
- Apr 9, 2016
- USA, FL
I just got a nice Tesa Hite 700 height gauge, and I was wondering if there's a way to use it to pre-set tool lengths for my older machines that don't have probing built in.
I would probably need a flat probe tip so I can just catch the high point of the tool instead of trying to get it with the round tip.
I suspect you'd want to set the datum on the spindle gage line instead of on the flange of the CAT40 holders, so that would mean I need something ground to an internal CAT40 taper with a datum point available to zero the height gauge on. Is this a product that already exists, or would I need to roll my own?
Obviously this is no replacement for a Speroni optical presetter, but it would be much faster and safer IMO than touching off with the little dial gauge in the machine. Easier for less experienced operators as well.
