Using Trigonometry for manual programming
Page 1 of 5 123 ... LastLast
Results 1 to 20 of 87
    Feb 2021
    Washington
    18
    Default Using Trigonometry for manual programming
    Hello all,
    Extreme novice machinist in training here. Iím currently enrolled in a CNC course at the local community college. Weíve covered a number of basic skills so far such as setting work coordinates, tool length offsets, dialing in a vise, picking up an edge, picking up holes and bosses, etc. Weíve also got the chance to run a few programs to make some parts out of stock that we squared up on the manual mills during the last course that I took.
    This last week, homework has been about using trigonometric functions and right triangles to find missing dimensions on prints. Itís been very challenging for me as before these classes I havenít really done math since about 2005 in college. haha. And even then I never did take a trig class. So Iíve kind of given myself a YouTube crash course in trigonometry over the last week and learned Pythagorean Theorem and all that so I could maybe understand what weíre currently learning.
    Iíll attach a pic to this post. What theyíre looking for is for us to be able to calculate the two XY points of a blend arc. Iím not asking for anyone to do my homework but I feel if I could at least see the right triangles required to do the math I might have an ah ha moment and be able to figure out other similar problems with missing dimensions. So if anyone would care to draw the required triangles or point me in the direction of a good resource it would be much appreciated. Iím just trying to learn all I can and this stuff has me stumped. I have class again on Thursday and would like to come in with some knowledge.
    Thanks for any help. Hopefully this was the correct forum to post in.
    Drew
    Feb 2021
    Washington
    18
    blend-arc.jpg Here's a pic of the print
    Jun 2012
    Michigan
    5,808
    5498
    3704
    Quote Originally Posted by Dhoverson View Post
    Excuse the curvy lines, I'm not right handed and can't draw with a mouse.
    On the Vertical line where the red and green meet are your 90 deg angles for each triangle.
    Sep 2010
    Victoria Australia
    4,082
    1712
    Quote Originally Posted by Mtndew View Post
    Hello Mtndew,
    Maybe I'm not seeing it, but I don't believe there is enough information to be able to use the triangles you propose. The only known side of those two triangles is the hypotenuse of the lower triangle.If you knew the chord from P1 to P2, then Heron's Form could be used with your two triangles.
    There are more elegant solutions to this problem, but for the OP to use Trig, I think he would need to get the angle of the line from Y0.5 and tangent to the arc.
    To do this, the acute angle of the Green Triangle (two sides known), shown in the following picture, will allow the acute angle of the Blue Triangle (two sides known after the Green Triangle is resolved)to be calculated. The combination of these two acute angels will allow P2 to be calculated using the Magenta Triangle.
    Regards,
    Bill
    Feb 2021
    UNITED KINGDOM
    First post, thought I'd better try and input something before I ask Bill about Fanuc servo drives!
    Excuse the grease.
    Your tutor is evil.
    No one will ever give you a drawing like that. They are normally dimensioned to the intersection
  6. Likes barratt liked this post
    Sep 2018
    15
    11
    6
    Welcome to the trade. You'll regret it later. lol
    Here's a fun one for you.
  8. Likes ixohhoxi liked this post
  9. #7
    Sep 2002
    People's Republic
    5,828
    701
    3646
    trackball....................without CAD I think you are short a dimension for a solution, either and angle somewhere or a length or something. Where are the Y locations of those triangles ? In CAD you just draw the circle and make a tangent line and pick the point.
    [edit] just figured out Franks scrawl, damn what a pain, CAD is faster, I suppose they make you use trig tables too....
  10. #8
    May 2017
    Minnesota
    1,743
    2261
    1156
    In industry, the correct answer is to spend three minutes to draw it up in Solidworks. Too much time and chance of error when you do it longhand. That said, it's good to be able to do that sort of thing longhand; I once had to prove longhand that the output of a rolldie post processor was correct before the customer would have their machine checked. Turns out they needed servo tuning.
  11. #9
    Apr 2018
    7,361
    3593
    Quote Originally Posted by mhajicek View Post
    Absolutely, but the point of a school is to teach you how and why something works. When you know the whys you can take shortcuts, but if you don't even know why, you're lost. As we can see in many posts here asking very elementary questions.
    I also think that particular drawing is evil, but obviously it was intended to be
  12. #10
    Jun 2012
    Michigan
    5,808
    5498
    3704
    Quote Originally Posted by angelw View Post
    Hello Mtndew,
    I know, he was asking how to draw initial triangles to solve problems like this.
    I didn't want to do his homework but I gave him an example of how it's done (if all of the dimensions were there).
    Plus it was early I had just got into work and hadn't had my caffeine yet.
  13. #11
    Jan 2007
    Flushing/Flint, Michigan
    10,173
    575
    8318
    Quote Originally Posted by EmanuelGoldstein View Post
    This seems very evil for students just entering the world of trig. Is it meant to teach one that cad is much easier?
    There is a button for line tangent to circle through a point. There are of course two but only one makes sense and the cad figures out which from the picks.
    Wonder what project 53-06 was?
    Bob
  14. Likes yardbird liked this post
  15. #12
    May 2019
    1,911
    1056
    1227
    Everyone knows math is racist and 2+2=5
  16. #13
    Feb 2021
    Washington
    18
    Quote Originally Posted by thedude31 View Post
    Haha! That one looks like a headache. I really appreciate the responses everyone. Iíll take a look at your examples and see if I can make sense of them. I work in the Aerospace industry in WA. Been in if for 10 years now building commercial airline interiors. Everything from working on moving lines building luggage stowage bins to running larger infrared ovens for a vacuum form process for applying decorative laminate to parts, to now for about the last year Iíve been a 3 axis router table operator. Running the 3 axis routers isnít a terrible gig. They give you your work package for the day and you just keep the machine running.
    However, I really wanted to get a transferable skill under my belt. Something that could be applied to any industry in just about any place my family and I would ever live. I started looking into all things machining a while back and felt really drawn to it. Itís definitely the most technical, and vast subject matter Iíve ever looked into. And I thought going through automotive tech school back in 2005-2007 was technical. Haha!
    We have tooling machinists at work that work on press dies and such. Iím aiming to get into that shop and go from there or get into the apprenticeship program if I can get accepted. Itís very competitive and not opened up very regularly. Iíve been bitten by the machining bug so bad Iíve even considered selling an extra vehicle we have to buy a mill for the home shop. Haha.
    I hope to continue learning and as such hopefully I can contribute to this board some day. Iíll be sure to post some pics of the finished parts from school when Iím done.
    Thanks again for your replies everyone.
    Drew
  17. #14
    Dec 2004
    San Antonio, Texas
    216
    36
    242
    I hope to continue learning and as such hopefully I can contribute to this board some day. I’ll be sure to post some pics of the finished parts from school when I’m done.
    Drew
    You'll do fine. I also used community college to break into machining. And then I used it again to break into NC programming. Onwards and upward!
  18. #15
    Feb 2021
    Washington
    18
    Quote Originally Posted by davehud View Post
    Right on. Glad to hear I'm not the only one. The machinists at work tell me to never stop learning. They take a Mastercam class every year to stay current among other things. Feels good to turn the brain back on after a decade of doing repetitive manufacturing.
  19. #16
    Sep 2010
    Victoria Australia
    4,082
    1712
    Hello thedude31,
    You've got to make it a bit harder than that for him.
    The hypotenuse = 8.6023
    Therefore
    A = 7 x 5 x 0.5
    A = 17.5
    Where:
    A = Area
    HP = (7 + 5 + 8.6023) / 2
    HP = 10.30115
    Where:
    HP = Half Perimeter
    R = A/HP = 17.5 / 10.30115
    R = 1.6988
    Regards,
    Bill
  20. Likes jz79, thedude31 liked this post
  21. #17
    Feb 2008
    MI, USA
    957
    70
    395
    Hello thedude31,
    Therefore
    A = 7 x 5 x 0.5
    A = 17.5
    Where:
    A = Area
    HP = 10.30115
    Where:
    HP = Half Perimeter
    R = 1.6988
    Regards,
    Bill
    I've had lots of higher maths and I've never been taught this shit. Wtf
    Semiperimeter - Wikipedia
    Learned something today. A=rs. huh.
  22. Likes Conrad Hoffman, mountie liked this post
  23. #18
    Dec 2004
    San Antonio, Texas
    216
    36
    242
    I had a 40 year career in aerospace. Loved it. From running engine pylons on manual DeVliegs to programming landing gear parts on a 5-axis rotary head gantry.
  24. Likes Johnhudson, Dhoverson, mountie liked this post
  25. #19
    Sep 2018
    15
    11
    6
    Hello thedude31,
    Therefore
    A = 7 x 5 x 0.5
    A = 17.5
    Where:
    A = Area
    HP = 10.30115
    Where:
    HP = Half Perimeter
    R = 1.6988
    Regards,
    Bill
    Dear mother of god... lol
  26. #20
    Nov 2004
    RC, CA
    2,187
    224
    472
    I had something like that to program a wire EDM to make a die. It had a tab hanging off part of it, not fully dimensioned. I struggled and struggled with it, and after many steps had a solution the machine would accept. I figured I just sucked at Trig.
    Some time later a rep for the machine dealer stopped by and saw it. He'd been through some CAM classes, 'that looks pretty tough, how did you program it?'. By hand. 'Umm, how would you like to teach a programming class?' No thanks.
    I've seen a lot more since. And as already noted, I generally draw it up in CAD and pull numbers off of it. Unless I'm feeling like I need a challenge for some stupid reason.
