Using up 3/4 inch carbide endmills too quick
Results 1 to 12 of 12
    Feb 2016
    South Dakota
    77
    Default Using up 3/4 inch carbide endmills too quick
    Hey guys, I'm having a little trouble getting more life out my 3/4 inch carbide endmills. I only get to use them about twice before they need to be resharpened. Granted each time is on a 6 to 8 foot brake that I mill. I only have it running at .1 Z depth and it only fully engaged on each part for 200 to 300 inches at about .050 depth. The rest of it is side milling maybe .05. I'm cutting 1145 steel and my endmills are solid carbide. I'm using flood coolant, spinning the endmills at 1790 RPM, and feeding at 30 IPM. This next time I'll try it at 20 IPM. What am I doing wrong? Thanks!
    Sep 2007
    Washington
    5,238
    198
    1578
    Sounds like you are using your endmill like a facemill, if it's only .05" deep and 100% engagement. I would try an inserted facemill instead. You can tune the inserts for the material and conditions, and inserts are cheap compared to 3/4" carbide.
    If not that, how about stubby 1/2" endmills? You need more passes, but cutters are much cheaper.
    Regards.
    Mike
  3. Likes Bobw liked this post
    Feb 2005
    9,046
    13903
    10717
    350sfm, is the steel hardened or no???
    I'm going to say that your problem is that you are running coolant.
    That thermal shock thing..
    From too much experimenting, I've found that (at least for me), the break point
    from wet to dry is about 300sfm in mild steel.. Lower for harder materials.
    Are you coated???
    That dark purple stuff gets slicker than snot and hard as hell when it gets HOT!!!
    If you are running coolant, you may not be generating a high enough temp to let the
    coating work its magic.
  5. Likes Mtndew liked this post
  6. #4
    Jun 2012
    Michigan
    4,730
    4336
    2876
    Quote Originally Posted by Bobw View Post
    Are you coated???
    This would be my suggestion as well.
    Cut it dry.
    And maybe use an indexable shoulder mill for the .100" depth cut.
    OR
    Or get an endmill with a larger corner radius.
  7. #5
    Sep 2005
    Oakland, CA
    2,494
    297
    672
    that's a chip load of .004 on a 4 flute tool and about 350FPM. You don't mention the failure mode of the end mill- wear or chipping or? Is this a coated tool or?? My guess is its thermal shock from your coolant but that's only 1 possibility. I have had good luck with coated tools and an air blast in steel. Blue chips are a good indicator of getting the heat out in the chip and that's a combo of RPM and chip load. Have you consulted the tool manufacturer?
  8. #6
    Oct 2009
    near Seattle, Washington, USA
    1,453
    477
    797
    How is your part fixtured? If it's allowed to bounce around it's going to beat the crap out of your cutter.
  9. Likes bryan_machine liked this post
  10. #7
    Feb 2016
    South Dakota
    77
    The endmills are not coated. The Steel is not hardened. I'm running 350 SFM. The endmills are wearing down on the corner and then starting to chip. I'm roughing out the pocket with a 1.5 inch carbide inserted cutter and going back in and finishing with the 3/4 inch. I'm using endmills with a sharp corner to get the 90 degree edge in the pocket. I don't have air blast capabilities at the moment. The chips are coming off with no color change. I'm running a vertical mill so if I run without coolant the chips should fall away. I'll probably try cutting it without coolant this next time. The part weighs about 800 pounds and is fixtured vertically. I've got it hanging pretty solid. I'll probably try it without coolant next. Thanks for the tips!
  11. #8
    Feb 2012
    CANADA
    Ontario
    1,126
    89
    433
    Like others have said.
    1) It is not aluminum, so even carbide will wear. If you don't want to wear off the tip, use indexed endmill for facing operations. ALso ditch coolant.
    --OR--
    1) Use coated carbide.
    2) Ditch Coolant
  12. #9
    Oct 2009
    1,453
    477
    797
    Quote Originally Posted by RustyRedneck View Post
    In that case it might be more economical to rough with a 3/4" cutter with either radiused or chamfered corners and then come back in with a smaller sharp corner cutter.
  13. Likes Bobw, kevin66, doug925 liked this post
  14. #10
    Dec 2008
    New York
    10,212
    2652
    usually measure tool life in minutes with 60 minutes often considered normal tool life.
    tool length and tool holder length can effect cutting parameters easily 100 to 1000% . normally its best to try different cutting parameters and record data. tool life, amount milled, surface finish, any sudden tool failures, normal wear or failure mode.
    like any scientist you try experiments and record data. then decide on whats better to do.
  15. #11
    Feb 2016
    South Dakota
    77
    While I was gone the boss ordered a 3/4 inch inserted endmill and it showed up other day. Programmed for it and away we go. Seems to be working well so far. may have eliminated the carbide endmill from this process.
  16. Likes SND liked this post
  17. #12
    Aug 2016
    ALAND ISLANDS
    1,393
    43
    96
    hy / a bit late, but :
    ... try not changing directions inside the material; improve the toolpath if possible
    ... check the dwells ?
    ... plunge @ corners
    ... what holder is it ?
    check for variants for the tool corner : radius, chamfer, sharp
    check if the new tool has bigger corner radius ?
    here you are ... finishing tools are better to be carbide integral than with inserts / if you will have problems with the new tool with inserts, consider a smaller integral one
    be sure that, when cutting the walls, tool is not cutting @ bottom
