Nerdlinger
Stainless
- Aug 10, 2013
- Chicago, IL
Hi Everyone,
---------- BACKGROUND INFO -----------------
We have an application where we turn 41L40 from .562" down to .200" in one pass (swiss) with a VBMT221 (.016 rad X 35 degree.) Most of the time it's fine and we'll get about 1,000 pcs per insert but from time to time the insert will shift in the pocket. This can happen right upon putting a new insert in, 500 pcs into a run, or anywhere in-between...the turned OD's get small by .001-.002 and the part gets long by .001-.002. When this happens I know what I am going to see when I take the holder out to inspect the insert....the (RH) insert essentially rotated CW a tick or two about the screw. (The attached picture shows this exaggerated for clarity-sake. The red circles indicate where the side of the insert contacts the holder after it shifts.) The insert doesn't have to rotate very much before its relief no longer protects the holder and then it - the holder - starts to rub on the material, and the cutoff then rapids into a spot that's supposed to be turned back but it's not so it blows up the cutoff and maybe its holder, blah blah blah.
Anyways, the Kennametal guy says the inserts should NEVER move in the pocket. Even if it IS just "too heavy of a cut" for that wimpy little VBMT it should still break the insert before it moves in the holder.
------------ SO HERE'S MY QUESTION --------------
Does anyone know what would cause an insert to move like that?
------------- MORE BACKGROUND INFO --------------
I have made sure the holder is clean, the insert is seated right and the screw it torqued down nice and tight, this has happened on new holders and old holders. I recently just turned the feed down from .002/rev to .001/rev and that didn't help so I don't think it's just load. At one point we were using VCMT inserts in the VBMT holder and I thought, "AH HA!" that's it! But alas it is still happening with the VBMT insert/holder.
------------- BONUS QUESTION ---------------
I know how a stronger insert geometry, like a CCMT (80 degree) over a VBMT (35 degree), makes the nose radius area of the insert stronger but does it make the rest of the insert any stronger somehow? Like, are they more stable in the holder or anything?
THANKS, AS ALWAYS, FOR ANY INPUT!!
