I recently took the plunge and bought the (very) low price Emco Venture VMC that had lost it's parameters.
It turns out, it's basically the same machine as a Bridgeport or Hardinge from the same timeframe, built in Taiwan (Finetech). I was able to get parameters to load (which went fairly smoothly after figuring out the RS232 settings).
I replaced the estop switch (broken), and have a new door switch on order (gummed up, and solenoid stuck, and fried the control board).
I'm seeing a 'low hydraulic pressure' fault - since the machine doesn't have hydraulics as far as I can tell, I'm assuming this is the air over oil knockout cylinder? Does anyone have any idea where this switch would be on this machine? The cylinder has a solenoid with 2 airlines, but it's quite hard to get at (head covers need to come off, and I can't jog in estop). Is this solenoid where I should be looking, or is the switch somewhere else? (even an idea what it looks like would be appreciated - parts list is less than helpful.
matt
matt
