taiwanluthiers
Cast Iron
- Dec 6, 2016
- Xinjhuan District, New Taipei City
I don't know a whole lot about CNC, never had the money to play with it but my neighbor who runs a CNC shop was showing me some stuff... basically setting the Z axis after changing tools. He used this device:
And you would carefully lower the tool until it touched and it reads zero, then you typed something (which I do not remember what). And that tells the machine what position is the bottom of the tool so you don't crash the thing. If I remember correctly you always -50 (in mm) because the device is exactly 5cm thick.
If it helps he uses Fanuc controllers, one is a Oi-MF and the other is similar to the Oi-MF.
Is there a good resource on Fanuc controllers? like a manual or something? It's not easy to use like those NYC CNC videos. (and honestly their machines are squeaky clean compared to the ones I work with, so I wonder if they do any real production at all). The controllers are really old, it takes PCMCIA cards and no USB (at least the PC card had a CF card reader in it). So basically no choosing the right field with a mouse but you had to use the right screen options...
