Up until recently we have used a HAAS Mini(with no auger) for our milling needs. Recently we purchased a HAAS DM-2(with auger)which has been a great upgrade.
The issue we are having is small shavings. We do a lot of brass cutting with .125 EM which produces very small shavings. We use the air blast instead of liquid coolant for many reasons but its also a lot less messy. The problem comes in when we go to change what we are cutting to something where we actually need the liquid coolant and auger. All of these small shaving that have built up, will clog up the coolant drain if we attempted to simply wash them down and are way to small to ever be pushed up the auger chute anyway.
So I wanted to reach out and see what other people have come up with. The most obvious solution to me is a wet dry vac, but I wanted to see what other innovative ideas might be being used? And if a wet dry vac is the solution what brands/models have been most successful for people?
Keith
Keith
