Interesting problem: When I fire up our old (1996, Fanuc O-M control) Leadwell 610AP VMC in the morning, it is always off in Y by a little bit. Sometimes it can be off by thirty thou and sometimes only a few, but y never ends up in the same position as it was the night before. Once I reset the Y work offsets it makes good parts all day long with nice surface finishes, so I don't think there is anything loose mechanically.
Now, for a little background on the machine: A year ago, the Y ballscrew seized up and was replaced with a factory new one. The first problem was that the new ballscrew was a different pitch, so we changed around a bunch of parameters and at least got the machine to work properly. The second problem was that the new ballscrew was 20 years old and was "sticky," so the surface finish on the parts was unacceptable.
So, out came the "new" ballscrew and in went the old (albeit reground and rebuilt) ballscrew. Parameters were changed back, the machine makes good parts, and all appeared right in the world. Until I fired up the machine the next morning.
Anyone have any ideas as to why this could be happening? I have a theory that the machine is "relaxing" overnight and when I turn it on in the morning the servo motor doesn't engage in the same spot every time. Maybe a parameter I overlooked? FWIW, backlash is a couple of tenths max, and like I said, it makes good parts once the Y offsets are reset.
Thanks in advance
Thanks in advance
