cosmos_275
Hot Rolled
- Jun 9, 2015
I'm making a part with a 2" tall wall and I'm using a 3/8" maritool reduced shank end mill to finish it. The finish looks good, but I can feel small edges left by each pass with my fingernail. I can get them out with the buffer, but I'm trying to figure out how to use this thing.
I'm taking 5mm pass depths, leaving .005" from the rougher. RPM is 3000, feed is 800 mm/min (31 IPM, chipload is 3.5 thou). I bumped it up to .010" stock left and 7mm depth passes, but that didn't help. The LOC on the tool is 3/4". Seems taking more would be more deflection, so more edges. Any advice is appreciated. Material is 7075. Thanks
