Wall finish with reduced shank end mill
Results 1 to 12 of 12
    Jun 2015
    165
    24
    36
    Default Wall finish with reduced shank end mill
    I'm making a part with a 2" tall wall and I'm using a 3/8" maritool reduced shank end mill to finish it. The finish looks good, but I can feel small edges left by each pass with my fingernail. I can get them out with the buffer, but I'm trying to figure out how to use this thing.
    I'm taking 5mm pass depths, leaving .005" from the rougher. RPM is 3000, feed is 800 mm/min (31 IPM, chipload is 3.5 thou). I bumped it up to .010" stock left and 7mm depth passes, but that didn't help. The LOC on the tool is 3/4". Seems taking more would be more deflection, so more edges. Any advice is appreciated. Material is 7075. Thanks
    Nov 2002
    3,112
    1489
    694
    1) leave less for finishing
    2) semi finish the corners first, then finish mill the entire ID
    3) shorten the projection of the tool in the toolholder
    4) grind off the sharp edge where the flutes meet the reduced shank
    If all else remains the same, try spring passes at different depths.
    Feb 2005
    8,632
    12309
    9837
    Is it the top of the flutes, or the bottom of the flutes causing the ridges??
    I'm assuming this is a square corner endmill? I'd toss some small rads or chamfers on the
    corners for starters.. Hard to tell without seeing it and feeling it myself.
    Dec 2008
    New York
    8,691
    2312
    Quote Originally Posted by CosmosK View Post
    if you use toy size tooling you will get toy size problems.
    Jul 2016
    New Mexico
    344
    58
    79
    In my experience (plastic and aluminum), those reduced shanks aren't good finishers.
    Why don't you use a regular end mill with 2" LOC? I would go with a 1/2" or 12 mm diameter.
    Destiny Viper (in inches) or Fraisa (in metric), are my favorite finishers.
    Jun 2015
    165
    24
    36
    Thanks for the help.
    I think the wall itself is part of the problem being thin.
    I think it's the top cutting edge making the ridges. I will try grinding them down.
    Oct 2006
    New Hampshire
    178
    71
    42
    Don’t use a sidelock holder as any runout will be noticeable between depth cuts. Use a nice quality hydraulic em holder or collet chuck. Unless you are burying the tool in corners, I would use more of the flute length .5-.625 dp depth cuts. Leave less material for smaller finish pass and add spring pass at every depth.
    Nov 2014
    Florida
    2,158
    1058
    1093
    Quote Originally Posted by DMF_TomB View Post
    Or maybe since you always bring up making your 10000000000 ton castings you are compensating??
    To the op, nothing to offer that hasn't been said...
    Jun 2015
    165
    24
    36
    Quote Originally Posted by BALNH View Post
    "spring pass" is new to me, sorry for the ignorance. I suppose that means run it twice, once for deflection? I reordered the leave material behind it (wall is just over 1/4" thick) and that did not help. Thanks
  10. Likes doug925 liked this post
  11. #10
    May 2017
    Minnesota
    345
    263
    188
    Yes, that is what "spring pass" means. I always run two or three passes for critical dimensions. Contrary to what some say it does remove material; a spring pass can shave tenths off of 17-4 H900.
  12. #11
    Sep 2017
    Wisconsin
    210
    100
    Yes, that is a spring pass. I found using that exact same tool to finish a 2.75" deep 6061 wall of about the same thickness I needed to take spring passes, at different depths than the first passes, as mentioned earlier. Everything cleaned up nicely. I found I had to really give that cutter a chip load using an ER32 9mm collet to keep it from chattering at longer stickouts. If the internal radii allow I would use a larger diameter cutter with longer flutes, but of course that is dependent on the geometry you need to achieve.
  13. Likes doug925 liked this post
  14. #12
    Jun 2015
    165
    24
    36
    The spring pass helped on the thicker of the two walls, although I didn't vary the pass depths. I will try that next time along with breaking the upper cutting edge. Thanks all.
  15. Likes doug925 liked this post
