toolfood
- May 14, 2018
- Des Plaines Il. USA
THE WAY OIL LUBERCATOR IS USING TO MUCH OIL. EVERY DAY THE TANK HAS TO BE FILLED OTHERWISE IT GOES OFF ON ALARM. IT SEEMS TO HAVE GOOD PRESSURE IF IT WERE LEAKING IT WOULDN'T HAVE PRESSURE TRUE OR FALSE. THE TIMER IS SUB24 IS FIXED AND CAN'T BE CHANGED. IT GOES OFF EVERY 140 SECONDS. VERSAMAX II THE ORIGINAL IS A TRAYBON UNIT SOME OF THE OIL IS SOMEHOWE MAKEING IT'S WAY INTO THE COOLANT THERES SO MUCH THE WASTE CONTAINER HAS OIL IN IT ALSO ABOUT HALF THE AMOUNT THE OILER PUTS OUT. WHAT ARE MY OPTIONS IF ANY I'D APPRECIATE YOURE FEED BACK.
