trademarkmachine
- May 31, 2011
- cincinnati
We have Mits m3 on a vertical machining center.
When we run parts using flood coolant, control will shut down completely. Just like you pushed the control power off button.
We can run same program with no coolant. Machine runs fine.
Machine will restart with no problems. No alarms.
Problem seems to get worse longer machine is run during the day.
We have replaced coolant pump and coolant pump contactor.
Contactor is 220 volt coil.
Any thoughts?
Any thoughts?
