What am I missing?? ( 3 inch face mill seco m15 )
Results 1 to 6 of 6
    Aug 2019
    7
    Default What am I missing?? ( 3 inch face mill seco m15 )
    I'm face milling steel plates from 45mm to 30mm. I'm using a 3inch 5 tooth facsimile with seco m15 inserts. Their site recommends ds 850 ish rpm with 50ipm feed at a .11 depth of cut. If I run ANYWHERE close to that my machine is destroyed. I can barely get away with 600 rpm at 4ipm at a .05 depth of cut. I'm relatively new to this side of the trade, I mostly dealt with manual lathe and milling but I've been tasked with mastering this. My machine is a mill port rhino IV with centroid control panel, 5000 rpm max.Am I being a dumb baby and can actually run these numbers or am I missing something.
    Feb 2013
    Madison, WI
    975
    1116
    629
    What machine are you running this on? You will get better answers with machine info.
    Aug 2019
    7
    I edited to include what I know about the machine
    Jun 2012
    Michigan
    4,643
    4248
    2803
    Quote Originally Posted by Jeet401 View Post
    The recommended speeds and feeds are for a stable setup and a machine that can handle those parameters.
    If yours cannot, then back off 20% or so on the depth of cut and feed and adjust from there.
    Feb 2014
    Sunny South West Florida, USA
    2,778
    10481
    3203
    I just googled your machine. Looks like a Proto Trak...
    I say cut that DOC by 1/3 and cut your feed to 5IPM and adjust from there.... Your machine is nowhere rigid enough to take a cut like that. You should be starting with Bridgeport parameters and adjusting from there.
    Aug 2019
    7
    You helped a lot, I backed to about .0393 so a 1mm doc at 800 rpm with 5ipm and its cutting good enough, I'll keep playing with it to speed the whole process up gradually
  7. Likes michiganbuck liked this post
