What are the Anti-Corrosion Treatments for Sheet Metal Processing?
Results 1 to 2 of 2
    Jun 2021
    CHINA
    Default What are the Anti-Corrosion Treatments for Sheet Metal Processing?
    As a Small Batch Sheet Metal Laser Cutting Supplier, share it with you. Sheet metal material processing is called sheet metal processing. For example, in practice, plates are used to make chimneys, stainless steel barrels, fuel tanks for automobile fuel tanks, ventilation pipes, eccentric elbows, circular places, Buchner funnels, etc. The key technological process includes cutting, sheet metal bending and fastening, bending forming, electric welding and riveting. How to complete the safety protection of raw materials for sheet metal processing? How to prevent corrosion of metal materials exposed to the gas? Anticorrosion has always been a big problem for metal products.
    Small Batch Sheet Metal Stamping
    1. Anti-rust treatment of rural sheet metal processing commodities.
    2. Sheet metal processing products are used as epoxy resin zinc-rich primer. The key is to use steel frame structure and steel anti-rust finish. The coating has excellent physical and chemical properties, is convenient for engineering construction, and has good supporting facilities. The main ingredients are: epoxy resin adhesive, curing agent, zinc powder, anti-rust paste, modifier, organic solvent, etc.
    3. Plate processing products are used as epoxy resin mica positive intermediate paint: as the connecting layer of high-efficiency anti-corrosion materials, it is used together with epoxy resin zinc-rich primer service facilities. Their function is to improve the sealing and anti-corrosion performance of the composite coating, and can also be used as an anti-corrosion and anti-rust finish. The coating is tough, has excellent adhesion and sealing properties, and has excellent applicability for front, rear, left and right coatings. Its components include epoxy resin adhesive, epoxy curing agent, biotite compound, anti-rust color paste and so on.
    4. The overall surface of sheet metal processing products. Its overall surface can be used as epoxy varnish, isopropyl titanate vulcanized rubber varnish, acrylic polyurethane topcoat, fluorocarbon spray paint, etc.
    Our company also has Small Batch Sheet Metal Stamping on sale, welcome to contact us.
    Jul 2006
    Hillsboro, New Hampshire
    13,711
    3007
    9141
    Reported to Don's email.
  3. Likes Orange Vise liked this post
