LatheLizard
- Sep 23, 2021
Hey guys. Brand new Hyundai CNC lathe. Im turning a simple, straightforward part with some tight runout tol .0003 o.d. to I.d
turning everything at once and parting off.
Rigid set up, 1/2 bar dia, 36 long scaled .700 out of Royal collet chuck, with correct spindle liner installed. Long story short, I thought cutoff was distorting the part. After I cut it, but before partoff, I put indicator on it .and o.d. reads less than .0001 but I.d. runs out .0008 - junk. I usually dont run very close to max rpm, but surface finish required it on this part. Its running about 3500rpm on o.d. And 4500 on I.d.
Turning down the rpm on the internal work solved the runout to less than .0001. I didnt have time to troubleshoot everything today, I know I can eliminate more possibilities, but Im thinking it has to be balance and or vibration in chuck at the higher rpm right? Like the long ass bar behind headstock? Any other ideas? Thanks in advance
