bastarddsm
- Feb 18, 2014
- Southern Illinois University
I'm working on some light fabrications on mild steel 1"x2"x0.065" rectangle tube. I have to cut 2 0.4"x0.6" oval holes, 1 0.375"wide x 0.08" deep slot across the 1" side, and then drill 24 0.312" holes on the other 1" side. Machine is a Tree VMC1060 with a delta 50 control.
I drill a hole in the center of the oval then use a 1/4" end mill to cut the oval using the pocket frame mill cycle on my control. Seems to work fine, makes a little noise, but I figure that comes with the material I'm working on.
Then I cut the slot using the 1/4" end mill to save a tool change. I've tried to run 2 parts, and both times it appears to get chip welding and snaps the end mill. It's a generic ebay 4 flute no coating.
I have 0 experience running steel in this thing, so I went to the internet and found a feed/speed chart and it suggested 350 sfm and 0.0017 ipt. So 5300RPM and 34ipm. I cut the feed down to 10 where it plowed across the part, and that made vibrant blue chips and a nice fireworks show before it snapped. Next go around I shot from the hip and slowed it down to 2000rpm and 8ipm, I didn't see much color in the chips this time, but it still had the flutes filled up.
how fast should I be going?
Also any tips for drilling holes without getting a large burr on the exit side (inside the tube that I need to remove)
