What Double Sided Tape do you use
Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Dec 2010
    UK
    32
    Default What Double Sided Tape do you use
    Years ago we used 3M Double Sided Tape with great success then it disappeared from the UK market. We then used Duck Carpet Tape (strong fixing with future lifting). Now that has disappeared.
    Both of these products never left any residue on the two surfaces we were sticking together. We have used loads of different types since but none come up to the same standard.
    All leave some of the glue on both surfaces which takes a lot of time to remove.
    Do any of you use Double Sided Tape to stick flat components to the bed of the mill and not get residue stuck to the component and the bed when lifting.
  2. Likes Jay Perez liked this post
  3. #2
    Oct 2007
    San Francisco Bay Area
    280
    46
    77
    3M foam double stick tape, 5 psi holding force. Similar to Scotch(R) Outdoor Mounting Tape: Scotch® Outdoor Mounting Tape.
    Works very well, though it is difficult to remove the tape from the part post machining. Doesn't leave any residue
  4. Likes Captdave liked this post
  5. #3
    Dec 2008
    New York
    10,339
    2681
    Default foam tape
    i use 0.030" thick foam tape to hold thin parts. depending on cutting oil and how hot part got some glue residue needs to be cleaned off. i use a hot razor blade decal remover and then use a spray citrus based adhesive remover. Some adhesive / glue will dissolve with alcohol or other solvent. But many strong tapes are designed to be solvent resistant.
    some double sided tape is called re-positional tape. it sticks not as strong but normally can be removed with little residue.
    Gaffer tape is a tape that is not suppose to leave a residue and it is usually expensive. it is used on stages and movie sets and is easier to use than duct tape. it comes with glue on one or both sides depending on what kind you want.
  6. #4
    Dec 2008
    Arizona
    1,748
    178
    223
    permacel P02 have used it since 1988. use denautured alcohol to release with no res.
    P02 Double Face Paper Tape Permacel Brand 1/4" - 1" wide
  7. Likes Captdave liked this post
  8. #5
    May 2012
    CANADA
    373
    90
    Doesnt the tape affect machining precision since it can deform easily. So if you are milling, the part can be pushed down a little, etc.
  9. #6
    Jan 2010
    Indianapolis, Indiana, USA
    5,471
    2426
    934
    I thought that Google might return a manufacturer suggesting its tape for this purpose, but the results were mostly various discussion boards (PracMach, Chaski, etc.).
    3M does have a broad spectrum of industrial "bonding tapes":
    3M
    The Stanford Products Realization Lab has this document, which mentions "double stick tape" in passing; if you wonder what academics say about entry-level machining processes, this would be a candidate document:
    http://www.stanford.edu/group/prl/do...l/gnrlmill.htm
  10. #7
    Mar 2009
    Washington
    7,855
    5773
    10170
    Quote Originally Posted by cncdumm View Post
    I use 3m #410m and it's only about .002" thick. Super nice stuff for precision work.
  11. #8
    Dec 2008
    New York
    10,339
    2681
    Default double side tape
    i use 0.030" foam double side tape when i cut out the outline of a sheet metal part so depth is not critical.
    i find thin foam tape is better than thinner tape. it allows for part changing length as it heats and cools but still holds.
    try using hot melt glue to hold aluminum to steel. i found it strong BUT when i put the slightly warm part under cold water in the sink it fell apart. i prefer using something that will hold and if it fails that it does it slowly and a slight side ways shift giving me a warning. Having a part break free with no warning I find is far more dangerous.
    Rarely have i measured a part more than 0.005" off because the tape allowed the part to move under cutting forces
  12. #9
    Oct 2010
    New York,USA
    95
    14
    Years ago I used the 3M double sided tape to hold thin aluminum on a magnetic chuck on a surface grinder to grind it thinner with coolant and it worked out pretty good.
  13. #10
    Jul 2011
    AFGHANISTAN
    92
    11
    12
    I use Bron double face tape. Its really uniform in thickness. Down side its a major PITA to get it off. I have no idea what it costs but its probably not cheap.
  14. #11
    Mar 2006
    Vershire, Vermont
    2,244
    1503
    725
    Ditto for Permacell. It peels off easily and doesn't leave any residue. No idea where to buy it now, but the roll I bought 15 years ago is only half gone.
    Neil
  15. #12
    Feb 2001
    Redwood City, CA USA
    5,124
    204
    1021
    Old post, I know, but I figured this was better than starting a new thread. Someone in the HS robotics world suggested putting 3M blue masking tape on the part and sacrificial substrate, and then spreading superglue over one side and sticking the tapes' back faces together. I tried it with 1/8" 6061 Al plate on MDF, and it worked really well. I was running a 1/4" 2-flute EM at 4000 RPM (max for the machine) full depth at 10 ipm on nested parts. I did include small tabs widely spaced. I was using coolant, which wrecked the substrate for reuse, but it held well for the job and was easy to separate afterwords. The superglue seemed to soak into the tape and disappear, but it was still effective.
  16. Likes Colt45 liked this post
  17. #13
    Mar 2015
    Florida
    443
    822
    255
    Interesting, I have a part coming up that might just work for that.
    Gary
  18. #14
    Dec 2002
    Pacific NW
    5,169
    8
    884
    For years I used a 3M tape. A customer would buy a case and we'd share. On the inside of the roll the cardboard core said 3M, but no part number. The thickness was accurate at .007".
    We used it for milling delicate plastic and non ferrous parts. Alcohol freed the parts if they couldn't easily be peeled up. The adhesion increased with time so we found it wasn't a good idea to leave a part stuck overnight.
    A 3/4" roll was in the 20 buck range. It looked identical to regular masking tape.
  19. Likes Jay Perez liked this post
  20. #15
    Dec 2008
    Portsmouth, England
    880
    291
    551
    I have used this successfully for a number of years:
    Milling/Routing/Engraving Materials - Double Sided Tape
    It's easy to work with, holds well, and lets go without residue when you ask it to. I understand from Techsoft's rep that they have it specially made to their own specification since the manufacturers keep changing the formulation of the commercial stuff.
    George
  21. #16
    Feb 2013
    Idaho
    765
    172
    881
    I'm going to be the sissy here. If you use two sided tape or glue, always be prepared for the entire sheet of material to break loose suddenly. We had that happen with about a 12" by 12" by 1/8" sheet of aluminum. This had sufficient force to completely penetrate the stock Plexiglas shield on a Haas. It would have eviscerated the operator of he had been standing there. I'm not saying don't do it, just be aware that this can happen.
    A couple of keys that I have found is to completely clean the base plate and material with a fast drying solvent before sticking it down. Then, I use my spindle and a 2x4 as a clamp to hold it down until it sets (1-5 minutes). I just watch my z axis load until it starts coming up to ~25%.
    And since I'm a self described sissy, I try and add some sort of mechanical hold down as soon as I can if I am running a large endmill with any sort of authority.
  22. #17
    Dec 2008
    New York
    10,339
    2681
    Amazon.com sells just about everything including double sided tape
  23. #18
    Johnny Larue Guest
    stone off the table real good...wipe with acetone or isopropyl alcohol....use this tape or tape that is smooth and not bumpy holds better....take a mallet and maybe a 3x1x12 parallel and smack it down using the parallel so each smack is flat on and smaknker entire stock down....this will not come off unless you soak in coolant or acetone again...using a small endmill will not break the piece loose...never go over about 1/2 endmill for any shape....and I usually cut about .005 above material and then .0005 into tape on last pass or leave .003 and stamp them out....you can cut even the hardest material but you gotta go only .01 deep per pass or use a 1/4 endmill...less forces....and I hold the air gun aimed at cutter entire time WOT to eject glue balls and chips...its scotch #410M
  24. Likes Jay Perez liked this post
  25. #19
    Nov 2007
    Alabama
    1,545
    184
    284
    If you can get this over there, try it.
    Works great and made for what we do.
    Mitee-Grip™ | Mitee-Bite Products LLC.
  26. #20
    Feb 2020
    New York
    Like John Welden and Johnny Larue we used the 3M 410M double sided tape, 2" width, in the Kodak prototype shop I worked in. We primarily machined various plastics and aluminum using air or a light mist so we didn't have to worry about coolants softening the glue. As others have noted, if you properly flattened and cleaned the surfaces you would have a bigger problem getting the part off the table than having it come off while you were cutting it. This was by far my primary method of holding a part for machining.
    Every mill had a squeeze bottle of alcohol (don't remember the exact formulation but it wasn't denatured or isopropyl) and an artist spatula to help release the parts. As mentioned, you didn't want to leave the part taped down for any length of time or it would become very difficult to remove.
    Like Johnny said we would typically leave a .003" - .010" web at the bottom which was easily removed with a sharp blade and light filing. By not cutting through to the tape we avoided having the glue get wrapped around the cutter and also prevented any cutting fluids from getting to and softening the tape.
    We did have a pretty serious accident one time using the tape to hold down a 1/4" x 12" x 12" aluminum part. Our machinist had cut around the perimeter of the part leaving a .010" thick web of material to help keep it secure. He then drilled a 3/16" diameter hole near the corner of the part. He hadn't 'lipped' the drill so when it broke though the bottom of the plate the helix on the drill lifted the corner of the part up ripping the .010" web and releasing the tape. The spindle was running about 3300 RPM and the plate traveled up the helix and started spinning very fast. After only a second the force broke the drill and sent the plate flying across the shop. Our supervisor was standing about 15' away and the part hit him in the arm between his elbow and his shoulder. The force shattered his bone and pushed part of it through the skin on the other side of his arm.
    It could have been much worse. The guy he was talking to was sitting down at his bench and if it hadn't hit Gene it would have hit the guy sitting squarely in the back of his neck at the base of his skull.
    Sooo anyways, I tried to locate a source for this tape a few years ago and couldn't find any. Just located some at Zoro Tools and ordered a roll for $59.77 (Zoro #: G6910607) + NYS tax with free shipping. (Don't really want to give Bevos more money than he already has.) I suspect it will last me most of the rest of my life and I'll have to struggle to find it again.
