Jaxian
Stainless
- Feb 24, 2013
- Santa Cruz
When I got my Doosan mill the tech asked me if I wanted him to change a function that people found very annoying. I had no experience with Fanuc and said "sure whatever". He changed it in 30 seconds and I never thought of it again.
My Hyundai lathe does this same thing and it is driving me up the wall. No clue how to change it. Was hoping maybe you guys could help me out with the correct parameter/s to change it.
As delivered if you hit a limit it pops up the overtravel alarm and you can then back away from it. At that point you can't move back in the original direction until you clear the alarm with Reset button.
This leads to a lot of forward/back/reset repeat when trying to see where the travel limit is for some setup or task. Very annoying.
His change makes it so when you get the original alarm you only need to back up so it is not in overtravel and it automatically clears the alarm and you can move forward again no extra button hitting and no change to the controller screen or state. So you can creep up on the limit with the MPG or Jog very easily in small increments while watching the machine and not looking at the control.
Any info would be appreciated. Thanks
P.S. I would ask the tech but he is no longer with Ellison and not presently findable. He had a Masters in EE and was VERY software savvy so knew a lot of little tricks so finding it hard to find this.
